36,263
640
  • IQ Display of VLF stations no longer stable? [fixed in v1.344]
    Yeah, something is broken. I tried building older releases and discovered v1.296 (July 5) works. So now I'm going to have to painfully bisect all the versions in-between and figure out what's happened.
    Pretty much all those mil VLF stations use cesium (or better) frequency standards.
    WA2ZKDHB9TMC
  • wspr autorun is crashing my kiwi v1.337 [fixed in v1.338]
    Fixed in v1.338.
  • Reading signal strength from shell [option added to kiwirecorder]
    Okay, if you update to the latest kiwiclient / kiwirecorder then when in S-meter mode:
    "--dt-sec=sec" will average (as fast as possible) for that many seconds and then print a measurement result. This is different from "--s-meter=value_greater_than_zero" which averages for a specific number of averages. Naturally it is a conflict to use both --dt-sec > 0 and --s-meter > 0. If you are using --dt_sec you want --s-meter=0.
    "--ts", "--tstamp" or "--timestamp" will prefix the output with a timestamp. "--stats" works as before showing you the actual number of averages/sec obtained.
    Sample output. See the Makefile for command line examples.
    python kiwirecorder.py -s kiwi -p 8074 --s-meter=0 --ts --dt-sec=2 --tlimit=10 --stats
    26-Oct-2019 19:24:32 UTC RSSI: -111.2 3.0 meas/sec
    26-Oct-2019 19:24:34 UTC RSSI: -111.2 6.0 meas/sec
    26-Oct-2019 19:24:36 UTC RSSI: -111.2 6.0 meas/sec
    26-Oct-2019 19:24:38 UTC RSSI: -111.2 5.0 meas/sec
    26-Oct-2019 19:24:40 UTC RSSI: -110.9 6.0 meas/sec
    5.9 meas/sec
    WA2ZKDbensonHB9TMC
  • Cant find Kiwi (No I.P assigned)
    Reception looks good. Very happy to have another KiwiSDR located in the Middle East.
  • IP address blacklist seemingly doesn't [true only for proxied Kiwis, fixed in v1.336]
    Okay, today's v1.336 release now applies the ip blacklist to incoming connections made via the proxy. Because the filtering in done in the Kiwi server instead of iptables a Kiwi log entry is made when the blacklist filter hits. iptables is still used for non-proxy connections for performance reasons.
    The "ipt" shell alias now automatically includes the "-v" argument so you can see the packet counter for the iptable filtering rules. I.e. an incrementing packet count means the blacklist filter has been hit. Use "iptz" or "iptc" to clear the counters. These aliases can be used on the admin page console tab.
    PowernumptyG0LUJVR2BG
