36,280
642
  • IQ Display of VLF stations no longer stable? [fixed in v1.344]
    Yeah, something is broken. I tried building older releases and discovered v1.296 (July 5) works. So now I'm going to have to painfully bisect all the versions in-between and figure out what's happened.
    Pretty much all those mil VLF stations use cesium (or better) frequency standards.
    WA2ZKDHB9TMC
    WA2ZKDHB9TMC
  • wspr autorun is crashing my kiwi v1.337 [fixed in v1.338]
    Fixed in v1.338.
  • Reading signal strength from shell [option added to kiwirecorder]
    Okay, if you update to the latest kiwiclient / kiwirecorder then when in S-meter mode:
    "--dt-sec=sec" will average (as fast as possible) for that many seconds and then print a measurement result. This is different from "--s-meter=value_greater_than_zero" which averages for a specific number of averages. Naturally it is a conflict to use both --dt-sec > 0 and --s-meter > 0. If you are using --dt_sec you want --s-meter=0.
    "--ts", "--tstamp" or "--timestamp" will prefix the output with a timestamp. "--stats" works as before showing you the actual number of averages/sec obtained.
    Sample output. See the Makefile for command line examples.
    python kiwirecorder.py -s kiwi -p 8074 --s-meter=0 --ts --dt-sec=2 --tlimit=10 --stats
    26-Oct-2019 19:24:32 UTC RSSI: -111.2 3.0 meas/sec
    26-Oct-2019 19:24:34 UTC RSSI: -111.2 6.0 meas/sec
    26-Oct-2019 19:24:36 UTC RSSI: -111.2 6.0 meas/sec
    26-Oct-2019 19:24:38 UTC RSSI: -111.2 5.0 meas/sec
    26-Oct-2019 19:24:40 UTC RSSI: -110.9 6.0 meas/sec
    5.9 meas/sec
    WA2ZKDbensonHB9TMC
  • Cant find Kiwi (No I.P assigned)
    Reception looks good. Very happy to have another KiwiSDR located in the Middle East.
