- jks
- 32,341
- 331
sdr.hu registration error (mismatching IPs)
Well, as Stu points out, something is wrong that causes sdr.hu to see registrations packets coming from a public ip address that does not resolve to the same ip as the domain you're attempting to register with. They should match. It doesn't matter if that's a "household" public ip address or one on the end of a tunnel or proxy. -
Possible TDoA problem when using KiWi's in 3 CH mode [fixed in v1.255]
v1.258 is out with TDoA UI and reliability improvements:v1.257, 258 January 9, 2019 TDoA UI improvements: Added "4" button to zoom buttons at upper left. Zooms directly to level 4. Shift-clicking on the +/- buttons zooms by 3 levels instead of just one. Added distance scale (in km/m & miles/feet) to map at lower right. Added ruler function. Click on the "protractor" icon at lower right. Mouse cursor will change to cross symbol. Click on starting map position. Move mouse to ending map position and double-click to end ruler measurement. Or single-click to make intermediate measurement and continue. Click on icon to clear measurement. Don't use escape key as that will close the extension! (this may be fixed in the future) Admin GPS tab: now says "loading maps..." when display delayed due to map download process. By request: URL parameter "no_geo" to disable browser from determining and sending Kiwi the geolocation information of the connecting user. Use like other URL parameters, e.g. "mykiwi:8073/?f=5Mam&mute&no_geo" This will someday become one of the "user preferences" options.
Grove Project
GPS Question
