- jks
- 36,262
- 640
DRM Heard
Happy to see Voice of Nigeria using DRM mode C instead of the usual mode B to combat the selective fading and other problems. Even if it means their bit rate drops to 9.1 kbps (see table 5.2 "DRM system bit rates" page 21 https://www.drm.org/wp-content/uploads/2019/02/DRM-Handbook.pdf, bit rate also because MSC using 16-QAM and protection level=0). Also note their transmitter is ~110 Hz low, lol.
When HF broadcasters switch to using the xHE-AAC codec (like India uses for MW) they should get better audio quality using lower bit rates.
URL to get current user information [solved by parsing the log file]
Providing this information via a URL opens up a lot of cans of worms I don't have time to deal with. You can't provide user info accessible to anyone (like /status) because the privacy crowd will show up with torches and pitchforks (we've had enough trouble in the past with the issue of user ip addresses and geolocations). And you can't add a quick and easy authentication scheme (like adding the admin password in cleartext to the URL) without the security people jumping down my throat again. -
DRM Heard
@arnie: Station name in Chinese (via UTF8) is in today's v1.375 release. Thanks for mentioning that. -
v1.374: new TDoA algorithm
