- jks
- 36,250
- 639
Feature request - receiver info on status page [trial in v1.334]
Okay, there is a trial of this in today's v1.334, e.g. "kiwi:8073/users" Only responds to connections from the local network.
Response is JSON with a couple of the fields URI encoded. This mostly because it already existed as a protocol with the Kiwi Javascript and I've been trying to move everything to JSON anyway.
Example:
So a JSON array with as many objects as there are rx channels. Many of the fields can be an empty string value if there is no info.[{"i":0,"n":"ZL%2fKF6VO","g":"Tauranga,%20New%20Zealand","f":518000,"m":"cw","z":11,"t":"0:00:15","rt":0,"rs":"0:00:00","e":"","a":"192.168.1.2"},{"i":1},{"i":2},{"i":3}]- i: channel index
- n: name/callsign field, URI encoded
- g: geolocation, URI encoded
- f: freq Hz
- m: mode
- z: zoom level 0-14
- t: connect time h:mm:ss
- rt: time remaining type: 0 = no limit, 1 = inactivity limit will expire first, 2 = /24 hr limit will expire first
- rs: time remaining h:mm:ss (inactivity or /24 hr)
- e: extension in use
- a: user's ip address (as you would see on admin status tab)
- i: channel index
"Cannot use extensions while another channel is in DRM mode." - but no other DRM mode in use..
New links: rx.kiwisdr.com, map.kiwisdr.com, snr.kiwisdr.com, forum.kiwisdr.com
You can also use these links which might be slightly easier to remember: -
Kiwid can't start on BB-AI after update [spidev issue, problem disappeared with reinstall]
Neat. I did not know that would work. After a kernel upgrade you can also do:
Where all references to 4.14.108-ti-r123 above will be 4.14.108-ti-r124 in your case (it gets it from doing a "uname --r"). Restart after doing this.root@ai:~# cdp root@ai:~/Beagle_SDR_GPS# make install_kiwi_device_tree install Kiwi device tree to configure GPIO pins 4.14 4.14.108-ti-r123 cp platform/beaglebone_AI/am5729-beagleboneai-kiwisdr-cape.dts /opt/source/dtb-4.14-ti/src/arm (cd /opt/source/dtb-4.14-ti; make) make[1]: Entering directory '/opt/source/dtb-4.14-ti' DTC src/arm/am5729-beagleboneai-kiwisdr-cape.dtb make[1]: Leaving directory '/opt/source/dtb-4.14-ti' cp /opt/source/dtb-4.14-ti/src/arm/am5729-beagleboneai-kiwisdr-cape.dtb /boot/dtbs/4.14.108-ti-r123 cp /opt/source/dtb-4.14-ti/src/arm/am5729-beagleboneai-kiwisdr-cape.dtb /boot/dtbs/4.14.108-ti-r123/am5729-beagleboneai.dtb -
AMPRNet/Network 44 with KiwiSDR
There are a few public Kiwis listed using 44/8 addresses:
The "stats" tab for these might have an Owner/Admin email link where you could ask for advice.kiwi-kuo.aprs.fi:8073 Kuopio, Eastern Finland 44.140.163.27:8073 SM5YLG, SWEDEN kiwi-vih.aprs.fi:8073 Vihti, Southern Finland www.websdr.at:8073 OE4XLC, AUSTRIA
