- jks
- 36,250
- 639
v1.387, 388, 389
From the CHANGE_LOG file:v1.388 April 11, 2020 Desktop UI improvements: Added "tuning lock" to right-click popup menu. When active a single-click in waterfall or DX label area will briefly show a "tuning locked" overlay. Should perhaps be extended to include clicks in tuning scale. Does not effect other methods of tuning, e.g. entry in frequency box, click on +/- step buttons. Mobile UI improvements: Double-tap/touch brings up popup menu (same menu as right-click on desktop). Has tuning lock function same as desktop. Two finger pinch-in/out gesture will zoom the waterfall in/out. Tested on iOS & Android. -
Request for simple feature: tuning lock [fixed in v1.388]
v1.387, 388, 389
From the CHANGE_LOG file:v1.387 April 10, 2020 Admin page control tab: By special request, added ability to limit number of simultaneous non-Kiwi API connections (e.g. kiwirecorder). This works in the same way (and overrides) the TDoA extension setting that limits the number of simultaneous TDoA connections. DX label edit: Passband frequencies can be entered using "k" and "M" suffixes for kHz and MHz. I.e. "2100" and "2.1k" are equivalent, as are "1200000", "1200k" and "1.2M". However subsequent display of the passband field is always in Hz. So after entering "-2.1k, 1.2M" on the next edit the field will display "-2100, 1200000" (Hz). -
v1.387, 388, 389
v1.387, 388, 389
