36,249
639
    Just change the hardcoded "dtb-4.14-ti" to "$(DIR_DTB)". That's what I've done for the next release.
    iw2nkerz3dvp
    iw2nkerz3dvp
  • What is the status of the WSPR background and autostart features? [added in v1.181]
    Sorry (for those of you old enough: )
    Fix coming later today.
    k5mo
  • Kiwi Offline Due To CGNAT
    Hi Mark,
    This is a common problem, so you're in good company. I have emailed you two API keys for your Kiwis. Just enter them in the appropriate place on the connect tab of the admin page with the hostnames of your choice (presumably "emeraldsdr" and "emeraldsdr1"). Make sure to change the menu item at the top of the page to say "reverse proxy". Then use the restart button on the admin control tab.
    The DDNS becomes irrelevant when using the proxy. Your hostnames will be emeraldsdr[1].proxy.kiwisdr.com:8073 (note: always 8073)
    cathalferriso00scorpion00o
    Hi Mark,
