36,223
639
  • WSPR extension (non-autorun) not uploading spots to wsprnet.org [fixed in v1.694]
    Thanks Nate. I'm apparently not only stupid but blind as well. Bug took just a few minutes to find.
    Will be fixed in this next big release I've been working on.
    Holger
  • This is why we can't have nice things
    v1.689 (and later) has countermeasures against the "botnet".
    v1.690 (and later) is necessary for your Kiwi to resume using the proxy service.
    These updates will happen automatically overnight (local time) unless you've disabled automatic updates. You can manually update by going to the admin page "update" tab and clicking "build now" and waiting 30 minutes or so for the build to complete. Your Kiwi will restart when the build is complete.
    HB9TMCstudentkranitroenginejolo22
    Don't start multiple threads about the botnet topic. They will be deleted.
    The proxy service has been disabled because the money (for which I am not compensated) is now flying out of my back pocket:
    I will try and develop a fix in the code to better identify and remove these connections.
    Update: The proxy service has been re-enabled if you're running v1.690 or later.
    IK8SUTnitroenginestudentkrajolo22
  • PWM fan cooling for BBAI 64
    I used this one: https://www.mouser.com/ProductDetail/CUI-Devices/CFM-A225B-015-287?qs=QNEnbhJQKvb2DvAtDRPA%2FQ%3D%3D
    Note the important specs: low speed (1500 RPM), ball bearings, 5 VDC. It has wire power termination. So you'll have to splice in a short section of cable with a USB-A connector on one end if you want to power it that way. There are also USB-A connectors that have solder cups for terminating the wires directly. Also USB-A connectors with screw posts.
    I forget what the fan connector is on the AI-64. Not sure it is even powered without a proper PWM signal present, so check that first if you want to go that route. The AI-64 manual (or website) probably has the connector spec.
    WA2TP
    Well that's pretty strange. As mentioned in the v1.688 thread the most recent changes (including v1.687) were very simple and should have only effected stuff completely unrelated to spot uploading.
    Holger
