- jks
- 36,223
- 639
SNR Measurement (timing) enhancement [can be done via cron; /snr?meas url]
I turns out that setting is essentially bogus. You can override it easily. I didn't think it through carefully enough when implementing it.
Even if you're connected as admin from the Internet simply go to the "security" tab and set the switch that says
Restrict console connections to the local network?toNo. Then refresh the page, then go to the console tab and clickConnect. It should now work.The problem is that setting can't be in the admin interface. Otherwise it can always be defeated. This feature needs a setting similar to the one that disables the console tab entirely by creating a file called
~/kiwi.config/opt.no_consoleSee here: http://kiwisdr.com/info/#id-opt-dot
FT8 6m Autorun [fixed in v1.695]
v1.694 [hopefully a working version of the failed v1.691,692 update]
