36,739
670
  • Forgot your admin password? v1.803+ has an admin password reset feature
    Okay, I think the new admin password reset scheme is working well. See image below.
    The option will appear only if you connect from your local network. Not from an Internet connection (e.g. not from a Kiwi-2 serial number based proxy connection: 2xxxx.proxy.kiwisdr.com/admin). Use my.kiwisdr.com to find the local IP address link to your Kiwi's admin page (e.g. 192.168.1.101:8073/admin).
    You must also provide the Kiwi's serial number. This should be easy since it's written on the physical hardware (Kiwi-1: written in the white box on the Kiwi PCB, Kiwi-2: written on a label on bottom of case).
    As a further security measure the option will only appear for the first 5 minutes after the Kiwi software starts (power-up or software restart).
    So the restrictions should guarantee the Kiwi is in your immediate physical control. So no good for your remote Kiwi located 300 km away on a mountain top.
    If anyone can think of a flaw in this reasoning please let me know ASAP.
    Everything is carefully validated on the server-side. So anyone hacking Javascript on the browser shouldn't be able to exploit the scheme.
    Nate_Rstudentkrasmgjolo22Jordan1xJIMMY0311
    I thought of a way to add an admin password reset function. It has to be implemented very, very carefully so as not to cause security problems. I'll try and have this ready for the next release.
    TremolatsmgNate_RJordan1x
  • Maximum possible number of simultaneous users
    Same as with Kiwi-1. The number of simultaneous users varies depending on the FPGA configuration selected on the admin page, "mode" tab.
    But there are compromises as described in the text on that page. In 8 channel mode only 2 can have a waterfall. In 20.25 kHz wide audio bandwidth mode there can only be 3 channels etc.
    xq2cg
  • v1.802
    From the CHANGE_LOG file:
    v1.802 February 7, 2025
      Added support for multiple iframe instances, up to 16. (thanks VK3KHZ)
        Admin > Extensions > iframe has a new button called "populate with standard entries" which
        will add 6 new iframe entries in addition to the new "DX spots" default added last release.
        They are: solar conditions, K-index, HF propagation, lightning map, and aurora.
     Fixed bug preventing change of proxy host name in certain cases.
    nitroengineTremolatYogicatHB9TMCbensonG4ZFE
  • v1.801
    There's a problem in this release. Changing proxy connection host names is broken. Will be fixed soon.
    smg
