 - jks
 - 36,271
 - 642
Placing my own labels on my KiwiSDR
The label system needs a complete overhaul, but that's a separate topic.To do what you need there are a couple of options. If you're running a recent release (we're on v1.10 currently) you can edit the labels directly with the browser UI. See here: http://kiwisdr.com/quickstart/#id-user-markerBut that's kind of cumbersome because you'd have to delete each label, one-at-a-time, from 25 MHz up. Or worse, all of them since none would apply if you only have a transverter connected. So try editing the database file directly. FIrst, login to the Beagle with ssh or PuTTY as root. Type 'cdp' to go the project build directory. 'mst' to stop the server. 'cd ~/kiwi.config'. Make a backup copy: 'cp dx.json dx.json.bak' Then edit the file dx.json using whatever text editor on Debian you can deal with. 'nano' is not too bad. It uses control characters for commands. It has on-screen help. The dx.json file entries are sorted by frequency, so delete the ones you want. Restart the server by doing a 'cdp' and 'ku'.Your idea about adding an offset to the displayed frequencies is a good one and I'll add it to the wish list.
