36,739
670
  • First local wsprdaemon connections gets timeout counter [fixed in v1.811]
    I’ll bet this happens if there’s a delay determining the local IP. Although I don’t know why that would be. That should occur almost immediately. I’ll take a look.
    palomar
  • Not seeing my station in Public [fixed]
    Based on the info on kiwisdr.com I'm pretty sure your ISP is blocking all incoming connections. So using the DUC doesn't help with that. Your only solution is to use the Kiwi proxy service which was enabled by default on your Kiwi-2. You can change the proxy configuration to use your call instead of the serial number in the proxy URL as you did with DUC.
    MarkW3ILT
  • missing samples [not just a Kiwi problem]
    Yes, totally different code. Same principles though.
    Unfortunately none of this surprises me. A number of years ago Chrome had a bad audio problem. There was someone else who went to battle on the Chrome bug tracker, so I just sat back and waited. It was an ugly fight, but months later Chrome finally admitted there was a problem and fixed it. I was much too busy to get involved directly. I just told everyone to use a different browser temporarily.
    okron
    @smg No. The entire point of this project is for the Kiwi to not be yet-another-IQ-generator using external PC software. And all the associated headaches. There are plenty of existing solutions for that.
    If ever I feel I have no alternative but to go that way then that's the day I pull the plug. There's no point in continuing.
    smg
    So I would guess this is an issue with Windows and Chrome/Edge not being able to deliver the Javascript realtime requirements for the resampler. The fact that you're not getting any Kiwi under/overruns and the Qlen is stable kind of confirms that.
    This entire project is built on the idea that browsers live up to their promise of providing stable, well documented platforms for delivering content/media. And over the years I've been constantly disappointed in the delivery on that promise. I guess I shouldn't be surprised.
    okronF5AFY
