36,722
670
  • I keep getting a "connection refused" message in the browser [software install issue]
    Hi Bill,
    If your public ip is static (unchanging) then yes, you can use that in the domain name/ip address field on the sdr.hu tab of the admin page. If your ISP provides you a dynamic public ip then you have to use a DDNS service as we describe here: http://kiwisdr.com/quickstart/index.html#id-net-duc Some people who own their own domain use that domain name, or a sub-domain, in place of a hardcoded ip address.
    There should be no risk to your LAN (I know, famous last words etc.) When you modify the NAT settings on your router to re-direct port 8073 packets from your public ip address to the local ip address of the Kiwi that should be all that is allowed. There should be no other inbound connections possible, like to other computers and/or ports. On the Kiwi, accesses to port 8073 only transfer files associated with the Kiwi user interface and setup communication with the Kiwi server (i.e. audio and waterfall). There is nothing else that should be a risk. The Kiwi server might have its own security problems (it has in the past) where an attacker could crash it or change the configuration. But this should be confined to the Kiwi software alone and not a threat to your LAN.
    wjniemi
  • Bad parameters ?
    Yes, anytime the sound or waterfall processes receive an unrecognized command on the web socket stream a message is logged. But there is also a bug I recently fixed where _any_ command received after the server thinks the connection is "closed" is logged. This is incorrect and there will be a fix in the next release. You will occasionally see random stuff logged. Unless it is causing you a problem you should not worry about it.
    f1jek
  • No possibility to upgrade [fixed in v1.88, caused problems with new Kiwis first upgrade]
    Okay, please "cdp" and then "up" to download, build and start the new v1.88 release.
    sq5m
  • NOAA FAX
    Because reception of HF fax is poor here in New Zealand I've had to use one of the Kiwi beta sites in Europe to get strong reception of DDH3 & DDK3/6 out of Germany. That image has contrast problems. It should be a well defined black & white. The open source fax code I found is kind of strange. I don't really understand it yet. Especially the FM demod section.
  • NOAA FAX
    Which computer? Computer running browser or Beagle? Can you define "other operations"?
    The Beagle is only meant to be running the Kiwi server and nothing else. There are critical realtime constraints that require Linux to get-out-of-the-way as much as possible.
    On the client computer if the browser/javascript doesn't get the required realtime response to keep up with the audio output demand then you'll drop audio samples and the fax will get shifted. This can be improved by making the Kiwi audio buffer in the browser larger. But then the latency gets longer, and a different group of people get upset with me, lol.
