- jks
- 36,722
- 670
Interesting Signals
This helps quite a bit: https://www.sigidwiki.com/wiki/Signal_Identification_Guide From our friends at http://rtl-sdr.comA: JORN, Over-the-horizon-radar (OTHR) from Australia. Note the short intro tone in the middle of the passband. This distinguishes it from similar sounding signals like (for me) the Tiger radars of the SuperDARN network etc.http://www.iarums-r1.org/iarums/radar-2013.pdf [10MB file]E, G: FSK/RTTY
Would need to hear it or see zoomed in. But you're probably right.Others: Correct I believe. The best blog I know discussing HF digital modes: http://i56578-swl.blogspot.com -
v1.115: reduced audio latency, especially for local connections
Config: v1.113 - Now unable to view Admin pages using iPad [fixed in v1.114]
Probably not a Kiwi design issue, unless you've supplied your own, older Beagle that is known to have noise problems (see http://kiwisdr.com/quickstart/index.html#id-e14) What you describe is typical for one type of SMPS we've seen. 60 kHz is a common switching frequency.Switch off the other devices until you find the culprit. Try filtering the mains input to your Kiwi linear power supply and perhaps Ethernet and antenna feed line.There are plenty of Kiwis that are in very quiet noise environments with few system noise effects, e.g. -
Is there a howto for getting a kiwi on sdr.hu.
What's the error message? Is it from the "sdr.hu registration status" field on the sdr.hu tab of the admin page? Or the "status" field of the DUC section on the network tab?Since you're using DUC on no-ip.com, on the sdr.hu tab selection menu at bottom left, do you have "DUC Domain" selected? And does it show "the_host_name_you_setup.ddns.net"?On the network tab what yes/no answers do you get when you push the "check port open" button?
