- jks
- 36,722
- 670
External Control [e.g. antenna switch interface]
v1.161: FSK/RTTY extension
Yes, my software for EFR is already way beyond what was in the v1.161 release. It took a while, but I finally found more details for not only the framing but the telegram formatting as well. Also, I have actually heard HGA22 and DCF39 (but not DCF49) here in New Zealand. It happens right at sunrise during certain times of the year (greyline propagation). This was from November 2016 (note 5:39 AM local time)
V1.158 Audio Underruns ? [try browser site-data-clear]
Software control of fan in enclosure?
No software mechanism. The 3.3V on the Grove connector of the BBG the fan plugs into is a fixed voltage.You could buy one of the short Grove cables from Seeed. Connect to the BBG and run the other end out the slot where the antenna connectors are. Disconnect the fan from the BBG and run the cable out the slot also. Cut the two Grove connectors off the cables and wire up appropriately to a little switch. -
NAVTEX Idea [DX log mode]
