36,738
670
  • GPS fixes diminish [fixed in v1.218]
    Possibly fixed in today's v1.218 update. Please give it a try since it takes a while for this problem to manifest itself.
    M0TAZPowernumpty
    M0TAZPowernumpty
  • Software update in progress [not a problem]
    Faster rebuilds coming soon. We are switching compilers from gcc to clang.
    M0TAZ
  • GPS antenna alternatives
    Here's an example of all sats being available on all channels on a Kiwi in Iceland. As a bonus QZSS is being received (!) The signal is weak and only 9 degrees above the horizon. It only participated in this one GPS solution before sync was lost. But it was there!
    ChristophPowernumptyM0TAZ
  • TDoA known location markers
    It does this already (if I'm understanding your question correctly -- morning coffee hasn't taken hold yet).
    Before you start the process single-click on a reference station so its information is copied into the field at the lower left of the TDoA control panel. Or optionally type your own reference info, format: lat lon id description. Then the result maps will show that info in a marker in addition to the "most likely" position computed. Also, if you're specifying everything from the URL, you can just list the reference station id to have it pre-selected. Just like the Kiwis to use are specified. See below. Using the Google map ruler we can see the difference in computed to actual location is a bit over 20 km.
    M0TAZ
