- jks
- 36,739
- 670
Dead bit of the waterfall? [fixed in v1.222]
Yes, this is an actual bug. I had an email about it earlier today and have a fix that should go out in tomorrow's update.
The area you've identified turns out to be exactly the transparent box that the audio FFT explanation text appears in. I forgot to enable mouse events for the box (HTML div actually) so that's why you get the dead zone. -
Waterfall and scale don't agree [they won't if there has been no frequency calibration]
Any difference between the waterfall carrier of a known reference station and the frequency scale comes down to frequency calibration of the ADC XO clock.
At z14 each waterfall FFT bin is roughly 0.9 Hz. But how this translates into what you see on your browser screen is a little muddled because those 2048 bins are "stretched" and anti-aliased to fit your actual visible screen width. But from experience the one above (not yours I know) looks fine for 5 MHz WWV.
Do you have GPS clock correction working? Without GPS correction XO temperature variation may make the frequency offset at z14 look much worse than what you have. To see the exact ppm and Hz difference use the manual clock correction procedure (see admin page "config" tab). The XO spec is +/- 50 ppm @ 66.67 MHz without GPS correction operating. -
sdr.hu API key for an additional RX
I'm not sure (I don't run sdr.hu and don't know precisely how it works) The worst that will happen is that you will end up with duplicate entries that you cannot delete. Although this is more classically a problem when you change from using an ip address as your Kiwi's URL to using a proper domain name. -
Antarctica wspr
Not really interesting.
As a non-ham you can make up a callsign for registration on sdr.hu
See the instructions: http://kiwisdr.com/quickstart/index.html#id-sdr_hu
