ww6d
- ww6d
- 495
- 1
Thank you John for putting in the time and effort to figure this out. Let's just call my "case" an outlier. I'm happy that I now have an updated KiwiSDR with Debian 11.11 and prepared for the future. Vy 73, Doug WW6D
Thank you John for the reply and clarification. Here's why I made statement about formatting. I tried two SD cards, both had previous versions of Kiwi software on them for backup. When I inserted either one of them, and started the "create…
Quick follow up ... the procedure outlined by John on Operating info web page worked just like it was documented. I looked at the photo of the "boot button" to make sure the correct switch was held down during power up. I verified that I …
I apologize for the bandwidth... I just found this on the extensive Operating info. Sorry to repeat just the snippet of info but maybe it will help others (see below). 73, Doug WW6D Re-flashing once you have the SD card: KiwiSDR 2 owners: Detailed…
I am also having difficulty getting my Beagleboard Green to upgrade to Debian 11. Here's my currently running KiwiSDR: KiwiSDR 1, v1.808, 8 SDR channels, 12 GPS channels | Uptime: 1:12:46 | UTC: 17:03 | Local: 10:03 America/Los Angeles (PDT) Debian …
Shortcuts also working with my iPad Air and a Logi keyboard. Thank you! 73, Doug WW6D
Thank you John! ... Not sure what happened but I do remember doing a 'Beagle reboot' recently for some reason, and that must have used the old date/time. Typing the 'date' command in the Console, I saw that the date/time was incorrect. So, moments…
verion ... I meant 'version' variable in your curl -s string... Doug
OK ... here's 2 recent log entries: Tue May 24 20:04:15 02:09:12.150 ..2..... 2 WSPR DECODE: 2002 -25 -0.4 14.097026 0 AE0JS DM79 1534 23 (200 mW) Tue May 24 20:04:20 02:09:17.198 ..2..... 2 WSPR DECODE: 2002 -28 -0.4 14.0971…
I realize I'm probably the only one left who is *not* running wsprdaemon ;-), but here's my observation. I use the 'stand-alone' extension and let the KiwiSDR do the decoding. Here's my setup: KiwiSDR 1, v1.636, 8 SDR channels, 12 GPS channels | Upt…
You can count me in for one. Thank you for doing this! 73, Doug WW6D
BTW ... reboot Beagle fixed the clock. Now log file has correct date/time. 73, Doug WW6D
Sorry about the bandwidth with this... after I upgraded to v1.588, the clock on my Kiwi was somehow reset; checking the log file on a recent spot revealed: Sun May 22 14:18:05 12:20:25.806 ..2..... 2 WSPR DECODE: 1416 -27 0.5 21.096112 0 …
Not sure if this is related to the recent changes for FT-8, but I am running v1.588 and my “auto run” bands show spots being detected on the Status page, but the spots are not showing up on WSPRnet.org … When I invoke the WSPR extension from the br…
Thanks to Glenn for alerting me to the new extension. Works great here! I appreciate the additional tool for evaluating propagation. 73, Doug
Now the latest revision is 1.527. The problem seems to be that the CHANGE_LOG is not being updated...? 73, Doug WW6D
Works now as expected with v1.447. Thank you!
Had another thought about the WSPR extensions... I think the 'tally' of spots is the cumulative number for an individual receiver so probably my issue is likely not a problem (see my previous post). (I think I was expecting to see the spot count on…
Just upgraded to v1.446 and then set WSPR extension bands for 80, 40, 30 meters. Noted spots overnight. All looked good. Then, this morning, I went to the Extensions and changed the bands to 17, 15 and 10; then clicked on the new button Autorun R…
Thank you for the quick fix! 73, Doug
