sv1btl
- sv1btl
- 372
- 5
                These are frequencies that unlicensed operators use for their local contacts, using conventional tranceivers. You will find them on:- 6630 to 6725 LSB- 3435 to 3485 LSB- 1610 to 1750 AM. This is a band that many greek radio-operators use to test the…
                No answer to this topic until now... Maybe is rather difficult for this kind of a project, I guess.
                @Daniel, if there is a slight activity (e.g 1KHz qsy), the "counter" is starting again to count the time limit. That's why the timeout does not function as expected.
                @linkfanelYou can use "Inactivity timeout" set to 10-15' - the best way for listeners to limit down their occupation. @G8JNJ What does this mean "best receivers"? Most listeners define their needs according to their interests. So…
                Hi.Well, I am not very sure what is this all about "sort" and "rate" the receivers, and I am not very sure that I've understood what do the icons indicate for some (not all) receivers, but according to my opinion the best criteri…
                The next step will be maybe to increase listeners' slots!...
                It's working just GREAT!!!
                It's OK now! Thank you!.
                Yes, I can see it now.at http://rx.linkfanel.net. Will it be publish at sdr.hu, or shall we now use the new address?
                Thanks. The server is still public activated with the address : http://sv1btl.no-ip.org:8073, but this activity does not appear on sdr.hu.
                THX a lot!. I'll keep you informed.
                What I Have to do? Shall I communicate with them and ask for a replacement?Are you going to inform them about the problem?
                1.42 V on GSGN and 0.85 V on GMAG
                Paid withPayPal balanceon 2 March 2017 Ship toEmmanuel PAthens115 23Greece Transaction ID06L823047D328081X Seller infoWiMo Antennen und Elektronik GmbH+49 727696680http://www.wimo.compaypal@wimo.com Purchase details
                Check points voltage:* 5V IN = 4.78 V. * 5VE = 4.59 V. * 5V = 4.63 V. * 3.3V = 3.44 V. * 1V = 0.99 V. * 1.8V = 1.8 V. * 3.3A = 3.29 V. * 3.3G - 3.31 V. * 3.3V GPS = 3.26 V.
                I don't have an oscilloscope.The voltage measurement on GCLK is 0.91V
                This is the last screen, after a restart. "Search" last few seconds and then stoped again..
                Check for the voltages is OK. All of them.Maybe I have to live without GPS....
                GPS output gives 3.6 V and the same currency is at the other end of the coaxial, just before the antenna. So, there are not any coaxial problems.
                I;ve already placed a new antenna, with the same results.I've bought kiwi on February.
                Everything was just fine before 2-3 days. I thought that GPS came with the KIWI was damaged, I have placed a new one, but with the same results.
                Please have a look..
                No-IP is free for limited accounts and this will be a better idea, instead of dyn.dns
                Why don't you try Static IP on Kiwi and to setup the exclusion for the 8073 port on router for given internal IP?
                Works! Thank you!
                Maybe you have to post an announcement about this, for Chrome users.Thank you very much fo the efforts!
                No need! I've just received an update to Chrome (new version 58.0.3029.81 (64-bit) and the problem is solved. Thank you!
                I've now cleaned cache. The same problem in Chrome.I've tried to access admin's page from Firefox - success (!!!!)Trying via Microsoft Edge - success (!!!)This is the first time that Chrome doed not open admin's page.
                No, I'm saying that there is not any screen available - blank screen. Local or via another ip is the same.
                Yes, I do know this. But it has also some rather good software noise blanker and noise reduction options, which are useful too.
