nionios
- nionios
- 23
- 5
i must say thank you. i have done the the fresh git checkout with Linux commands. 1.231 version now. all ok. 73 de SV8RV Zakynthos isl. GREECE
la -la Makefile returned zero lenght. after df space is ok. root@kiwisdr:~/Beagle_SDR_GPS# git checkout error: object file .git/objects/05/727946863c405158da592362e6bf559dffaff6 is empty error: object file .git/objects/05/727946863c405158da592362e6…
root@kiwisdr:~# su root@kiwisdr:~# root@kiwisdr:~# cdp root@kiwisdr:~/Beagle_SDR_GPS# m update check make: *** No rule to make target 'update'. Stop. root@kiwisdr:~/Beagle_SDR_GPS# m update_check make: *** No rule to make target 'update_check'. St…
debian@kiwisdr:~$ cdp -bash: cdp: command not found debian@kiwisdr:~$ m update_check -bash: m: command not found nothing yet
power cycling .. resolv.conf has 2 lines with 2 nameservers (my routers ip and my providers dns server..)....i think file is ok ok log to console from windows admin interface console and ping to github.com is ok
