no update stacked in the 1.212 version [filesystem fixed with fresh git checkout]
from log file
UPDATE: build error, no Internet access? status=0x00000200 WIFEXITED=1 WEXITSTATUS=2
please help
thanks in advance
73 de SV8RV
please help
thanks in advance
73 de SV8RV
If that doesn't work, are you able to login to Debian running on the Beagle? E.g. using ssh from another Linux/OSX machine or PuTTY from Windows? If so, what happens when you do a "ping github.com" from the Beagle?
ok log to console from windows admin interface console and ping to github.com is ok
When logged into Beagle, enter the commands "cdp" (change to build directory) and "m update_check". This will try to fetch the new Makefile from github.com and compare it against the current Makefile. It should note the change in version numbers from v1.212 to v1.224 (or later).
If this works then try building the release manually with the command "up" (update).
-bash: cdp: command not found
debian@kiwisdr:~$ m update_check
-bash: m: command not found
nothing yet
root@kiwisdr:~#
root@kiwisdr:~# cdp
root@kiwisdr:~/Beagle_SDR_GPS# m update check
make: *** No rule to make target 'update'. Stop.
root@kiwisdr:~/Beagle_SDR_GPS# m update_check
make: *** No rule to make target 'update_check'. Stop.
still problem
anyway many thanks
cdp
git clean -fd
git checkout .
git pull -v
make clean
make
make install
make start
root@kiwisdr:~/Beagle_SDR_GPS# git checkout
error: object file .git/objects/05/727946863c405158da592362e6bf559dffaff6 is empty
fatal: loose object 05727946863c405158da592362e6bf559dffaff6 (stored in .git/objects/05/727946863c405158da592362e6bf559dffaff6) is corrupt
trying to to build from scratch
cd
mv Beagle_SDR_GPS Beagle_SDR_GPS.bad
cdp
mi
ku
73 de SV8RV
Zakynthos isl. GREECE
