n6gn
- n6gn
- 5,484
- 31
To the degree that NF is a good description, it's more like 20 dB. Noise floor in the absence of large signal is around -155 dBm/Hz. That's not quite good enough to meet ITU Quiet Rural with a perfectly matched 30 MHz antenna. But a preamp won't …
A notch rather than just flat extra attenuation could have a slight advantage in that since this AM signal is by far the big pole in the tent, knocking only it down might get the ADC down to where the top MSB isn't getting exercised. Keeping aggreg…
Your 580 kHz AM monster could probably do with a little suppression. I think I can hear IMD from it even in the noise at upper HF, which otherwise does have a little but not terrible line related/SMPS component. A notch to get that -21 dBm sign…
"The Kiwi receiver can be connected to this strong network, but how do I make it accessible from the internet?" Does that connection not offer DHCP and a path to the Internet for some reason that can be overcome? With the TP-link Client co…
You ask a very pertinent question. I think the users and uses of a spectrum or WF display are varied so there isn't a single best answer. My own uses usually tend toward using it is a measuring device. But that can be in the process of improving …
I agree with @ZL2P that static buttons, while convenient, take away valuable screen real estate that is better spent on dynamic data such as spectrum and WF. I'd like to see grid lines for both axes, 10 dB/div for Y axis in spectrum and 5-10 in X …
Another question: has anyone ever found an FM signal on the shortwave bands? What is most common on shortwave: NBFM or NNFM? You've no doubt had this question answered by now but, yes, there is significant NBFM activity between 29.5-29.7 MHz. I'm …
IMO the logic is indeed broken. While other systems may have a 'default' CW offset of 500 or sometimes 600 Hz to create a "pleasing" tone, this may be most often with LSB tuning rather than right-side-up USB tuning. I'm not a heavy CW op…
IMO you are missing something. Necessary to remove CM <==> differential coupling (asymmetry) in the antenna system. CM ground currents, and asymmetry mean that unwanted noise degrades the desired antenna signal. A balanced dipole or loop st…
I concur that a single metric such as obtained through an SNR algorithm is not a good tool to use for evaluation in real life situations. I further agree that human examination of spectra, particularly broad bandwidth ones with an eye on noise signa…
It was a filter built in a 50 ohm context, as demonstrated by 50 ohm SMA connectors. The lines from the connectors to the filter are not 50 ohm but something a good deal higher Z. Relatedly the lines between even his physically isolated resonato…
He would have done even better to pay attention to making the 50 ohm traces, indicated by the presence of the 50 ohm SMA, be 50 ohms. For FR4 that probably indicates a width/height of a bit under 2. https://forum.kiwisdr.com/uploads/311/EG29BNQFOX…
I'll leave it to Martin since I know little about MFJ-1886X but it appears that not only are signals very low but that there are very few below mid-HF. Since most places in the world have AM or MW broadcast stations nearby, it rather looks to me lik…
As both Martin and I have been suggesting, please present a spectrum plot so any similarly spaced lines, particularly down near the low end of a Kiwi's range, might be discovered. Very low frequency ingress will not be by way of (inverse square) …
OK. 'unwittingly disrupts" and "for the wrong reasons" can speak to the same mechanism(s). But the added preamp itself can be that method.
This seems to be a characteristic spectrum of a 15 kHz impulse or perhaps high odd harmonics of a 7.5 kHz square wave. These kinds of signals are often from fast edges of SMPS power sources coupling into receive systems. If you could forego the …
Martin The differentiating point I was trying to make is about 'local environment' You wrote that further improvement can only be improved by using a better antenna. I was trying to make clear that there can be and usually are multiple causes for…
Martin writes: "If it is 6dB or more, then your system is already noise limited by your antenna and local environment, and this may be the best you can achieve. Any further improvement can only be brought about by using a better antenna, or by …
If you use a broadband display, particularly one with min/max hold you can appreciate where the QRM is by the ham-band notch depths as well as how much it is hurting your SNR. Here is capture of reverse channel, user ==> Internet, Internet-ov…
"Well, its quite interesting that just moving the antenna a few feet, seems to increase the SNR by several dB." This is characteristic of near-field QRN/QRM. Field strength from nearby coupling can drop at fourth, sixth or even higher pow…
As Martin has suggested, much of the coupling to an HF antenna system from VDSL, BPL or DOCSIS uplink tends to be by way of common mode injected current rather than radiated, either near-field or far-field, means. Achieving high symmetry with atten…
Don't confuse lower levels with lower SNR, which can sometimes happen. A properly operating loop should have ultimate performance very similar to a similar sized dipole probe, at least up through mid HF, modulo antenna pattern in az&el which ca…
jks, That would explain it. I really couldn't tell the model from the picture if it wasn't the same thing. But it is sure impressive how sub-milliwatts ERP do at LF. I transmitted a bit on 475 kHz with no more than 500 mW ERP, probably somewhat les…
@smg Not to be too picky and it probably doesn't matter since it is all working usefully for you but... From your schematic do you believe that an air core coil of 15 turns x 60mm x 10mm is 1700 uH ??? I doubt that it is even 1700 nH. But I can…
Really? http://192.168.10.89:8075/?mute&keys=yyys seems to work normally for me on v 1.701
One absolutely can. Common mode current (not differential between pairs say) can be the most common cause of degraded noise floor. Current coming down the LAN (or PS), common to all conductors, flows into the 'ground' plane of the Kiwi (PS lines…
https://forum.kiwisdr.com/index.php?p=/discussion/3520/interference-a-galvanic-isolator I suspect you are largely seeing common mode noise on the coax transmission line. While the loop antenna might have good enough CM===> differential isolatio…
