At this point, the Kiwi is not accessible from outside my local network, if this should happen again, I will reconfigure my router and allow connections. Thanks again.
Thanks for the tip about rebooting everything. Even though I had no problems with anything else on my network (Netflix streaming was working without a problem), after rebooting the cable modem, the router, and the switch everything is connected to,…
Thanks everybody. Lots of good information. I have a few tings to try.
It's in a window, facing West. It's close to where I have a GPS that I use for a GDO, which has excellent reception.
Its actually moving, and should be here on Saturday. Yay!
@rrobinet - in your Massdrop account go to your transactions, then select the drop you want to contact support about. You should now see a "CONTACT SUPPORT" link under the transaction. You can also go straight to https://helpdesk.massdrop.…
Chris, mine also lists Edison, NJ, but you need to check the status of the shipment - if it still says "Label created", that means that all we know is that the label is in Edison, NJ. It does not say anything about where the actual box is.…
Just got a notification from Massdrop that my KiwiSDR has shipped. When I go to the tracking informing, it only shows that the shipping label was created. I wonder if they actually are shipping the item out via FedEx today, or if it left the factory…
I just sent an email to Massdrop support to see if they have any more information. If I receive anything useful, I'll let you know.
I did order one during the last active drop (beginning of August), with a (back then) estimated shipping date of 9/19. On 9/19 I received an email from Massdrop that "Due to an unexpected delay, these orders may ship later than the original est…
It's not just the waterfall - I cannot get any audio either with the new version. I am getting an error in the "Stats" view: (Image) The error ("audio overrun") comes and goes about every second (or maybe a little less), and t…
