- jks
- 36,340
- 642
207.246.64.0/18 (widened from 207.246.104.0/23) and 141.164.32.0/20 added to blacklist. @jks is there a place to report these clearly "spam" ip's or is it unwanted? The best we can do is maintain our own blacklist. Complaining to these hos…
Well, it will say "installed version v1.558" if that's the version of the currently running server binary (same as what shows on the "status" tab). What really matters is the second message line that says if GitHub.com has a newe…
Not it isn't. It's working fine. I can compile up a v1.558 binary, run it, click check now, and it says "Available version: v1.559". Just like it's supposed to (the current version of GitHub.com is v1.559). I can compile the current source…
After some careful Googling I found a couple of new distributors that claim to have Kiwis in stock. UK and Canada. Added to the list on kiwisdr.com front page. But be careful because we have absolutely no experience with them. Contact them directly …
No
I have this working now. What are some good fixed values to put in the "pre-record length" menu? (similar to the existing "squelch tail length" menu)
What happens when you click the red button instead? If you continue to get "short read" errors in the window below then this means your EEPROM has probably gone bad. You can live with a bad EEPROM. Nothing really requires a valid serial nu…
Do NOT use the cyan/blue button to write anything to the sd card. That button is the same as the button on the admin backup tab for making a backup copy of the eMMC flash filesystem. It has nothing to do with the serial number. Remember, the /mfg pa…
That's very strange. But here's what you can do. Instead of connecting to the admin page via /admin use /mfg to connect to the manufacturing interface. Click the yellow button and enter 4730 in the white field. Then click the green button. Hopefully…
Yeah, looks like a bug. Fix in the next release which should be soon.
For the problem of not appearing on the map: I changed the registration script that runs on kiwisdr.com to try port 80 if there is no answer on the configured port (typically 8073) when polling /status. It fixed this problem. We also had another use…
Okay, the next release will have a fix such that you can return the setting to none.
Okay, so your Git clone of the Kiwi sources is trashed (for whatever reason, power failure at inopportune time etc). Please try this from the admin page, console tab: cd mv Beagle_SDR_GPS B.bad gclone Beagle_SDR_GPS cdp m Build will take 20 - 30 min…
Yes, that should be relatively easy to do (I think). If you care about absolute timing of squelch openings then you really need to get a decent sound processing app. I use Sound Studio for Mac. Here is a 5 second squelch open in a 30 minute recordin…
A less painful alternative, if your Kiwi is accessible on the Internet (public or not), is to set a temporary admin password and email it to support@kiwisdr.com and I can take a look. Recent versions have more comprehensive error log messages when a…
Versions without anything of interest to users don't get a forum post. Use the console tab (or ssh/PuTTY to the Kiwi directly) and look at the file /root/build.log Post here or email to support@kiwisdr.com
As a short term workaround set that value to anything but none. The explanation is a bit complex. It has to do with the measures taken to combat the "bot" connections most public Kiwis see.
The problem is that a lot of recent network hardware doesn't support 10M anymore. It's 100M/1G only. So if I defaulted to 10M there might be problems with the Kiwi appearing to be dead to the network. OTOH, maybe a "smarter" algorithm coul…
No. I just checked and everything is working fine. An automatic update will not occur unless both of the switches on the update tab (check and install) are set to YES. If check alone is set to YES then a message will appear in the log if a new versi…
On the admin page, control tab, what value is set for the menu called Number of simultaneous channels available for connection by non-Kiwi apps ? Are you accessing this Kiwi from its local network or not?
There is a fix in the v1.559 release that just went out. It seems to work as shown by this audio capture. DC block engaged during the later half of the recording. See the new "SAM options" menu on the audio tab of the main control panel. S…
Yeah, so the Teensy-ConvolutionSDR data path definitely does not have a DC block for their wdsp-based SAM modes (but do for AM). So that explains the current situation.
My KiwiSDR is still on backorder You need to immediately get some clarity from your distributor about that. If your distributor is waiting to receive more units from Seeed then that's almost certainly not going to happen. Because all of Seeed's rema…
Thanks Daz. This is quite possible. I pulled the wdsp stuff out of the source code from the Teensy-ConvolutionSDR project. Unfortunately that project consists of a single monolithic 19,000 line source file. So I may have missed that there is a DC bl…
I ask that people please stop emailing me suggesting I add a "donate" button somewhere. Micro-transactions don't work for me. The reasons are complex and somewhat unbelievable. You'd only understand if you are, or have been, a US expat liv…
Well, you didn't do all the things I asked in my last post. And you haven't told us what you did to get this working now. There's nothing to make me believe this won't happen again at the next release. After 37 forum posts this is the worst installa…
Christoph added --resample relatively recently I believe. I'm not completely sure how good it is for this application (very small sample rate changes). So be sure to do some characterizations. But it seems now there are several potential methods to …
Yes, it is that. Still no incoming access, e.g. I can't get a response from a curl mykiwi.n2xd.com:8073/status Please send an email to support@kiwisdr.com and we can try something else.
You've done something to take your git clone off the master branch. Too much mucking about! What do you get from gbr ? You should see: * master remotes/origin/HEAD -> origin/master remotes/origin/develop remotes/origin/master gurl should show:…
This is just not enough information to tell what is going on. Please paste the entire build.log file here or email it to support@kiwisdr.com Also, what happens when you click the other buttons on the console tab: check GitHub ping kiwisdr
