- jks
- 36,330
- 642
Thanks Glenn. I have it on my list now. Almost certainly a float that needs to be changed to a double.
Can you be more precise about what "the system crashing" means? Does the Kiwi server restart itself? Does Debian stop working and reboot? Does the Kiwi audio begin glitching?
Please restart and let your Kiwi update to v1.632 -- Thanks.
Please see the v1.631 release thread (or the CHANGE_LOG file) for a description of the new /s-meter URL interface.
Yep, stupid bug. Fixed in today's release. The backups you made are fine.
The backup should be fine. Looks like some bug crept in while I was trying to get Debian 11 backups to work. There is an update going out today so I'll try and fix this.
Still working okay for me. So maybe it is just a network routing issue that ends up effecting only some Internet paths to your Kiwi. Those sorts of issues are very difficult to deal with. Because who do you complain to? Your local ISP will probably …
Got the latest three of you. I've had to start a spreadsheet to keep track so I don't double count the requests, lol.
Yes, but again, this a value that is used only for first time user initialization. When you move the slider on the user RF tab the kiwi.json value doesn't change (or at least it shouldn't). However, you can obviously use it the way you describe if y…
The kiwi.json config file value (init.rf_attn) is not the current attenuator value. It is the initial value of the attenuator if there is no cookie value for the current Kiwi. Just like all the other init.* values. See the top section of the admin c…
I moved the KiwiSDR 1 external attenuator posts to their own thread.
Okay, great. I have this working now and will include it in the next release.
I've never seen that error before. But Googling opens up one of the worst cans of worms I've ever seen: https://stackoverflow.com/questions/67191286/crbug-1173575-non-js-module-files-deprecated-chromewebdata-index%EA%9E%89530595551 There are about 5…
Would it be okay if the URL option acted as though you opened the DX label filter panel, entered the ident and/or notes search term, then closed the panel? (i.e. working as it does now, showing the label bar background in red to indicate it is being…
From here (NZ) I'm able to get in from Safari/Firefox/Chrome desktop no problem at all. Great reception on that Kiwi BTW. From the proxy logs I can see activity from various Thailand IPs. But no errors on the proxy server end. I see from the my.kiwi…
Never a waste of time. Lots of people find these threads useful. Sometimes much later on.
AM funziona bene per me. Qual è esattamente il problema? Non sembra corretto? Il pulsante AM non funziona? Hai provato diversi Kiwi da rx.kiwisdr.com? What version of Chrome? I'm using version 118.0.5993.96 ---- AM works okay for me. What exactly is…
"This page isn't working {Kiwi site name] isn't working" If that's an exact quote from the browser then it is suspicious. Doesn't sound like any browser message to me (I could easily be wrong of course). Could it be from an intermediate ca…
But a software revision will also be necessary... Sure. And in the last few releases I've been adding the changes necessary to support Kiwi-2 as I test the prototypes. So a single distro will support both. It makes my life easier.
Okay, I will mention the USE_LIBSAMPLERATE env variable in the README file. I only added the display of which resampler is being used in 10/15 version. So that's why you don't see it in your 10/10 version.
I assumed he was looking for a simpler solution that could be used with curl (or a browser) as with /status, /user, /snr and /adc rather than all the baggage of kiwirecorder. But maybe that's good enough.
Yes, this would be possible (*except for the https part). A while ago I would have said "no" because the only API to the Kiwi server we had was based on web sockets. Either from the Kiwi Javascript running in the browser or from kiwiclient…
The apt install libsamplerate in the GitHub README for Linux is more of suggestion as the exact details always vary. But glad you got it to work. What you describe about the sample rate numbers indicates that the latest Kiwi version of samplerate is…
Can you put your slow Kiwi on the Internet so I can look at it? Your existing public Kiwi is also pretty slow, at times. If you bring up the browser debug console, select the "network" tab and do some page reloads, you can see it stall som…
Re the BeagleV-Ahead: Nothing has been done about that yet. We had a thread discussing the situation https://forum.kiwisdr.com/index.php?p=/discussion/comment/16419#Comment_16419 The general impression I got was that it was too soon to be spending t…
You may not need to buy your own BeagleBone. Similar to before we will offer two purchase options: A complete system: Kiwi board, BB Green (software pre-installed), Enclosure, GPS antenna w/ 5m cable, SMA-M/SMA-M 200mm self-test cable. Kiwi board al…
I'll give it a try too. Kiwiclient / kiwirecorder is an alternative, programatic way of connecting to the Kiwi server running on the Kiwi board / Beaglebone combination. So the usual way looks something like this: (Browser + Kiwi Javascript client) …
Well, I worked all day on this. But it needed to be done. And as a side-effect I got a few things straightened out on my laptop that I'd been postponing. So please update your kiwiclient. The new version will use a local copy of the samplerate modul…
Alright. Let me take a quick look. I suggested before that simply incorporating the python-samplerate source code into kiwiclient, and applying Christoph's fix, might be the simplest thing to do. That will either be simple or difficult due to the am…
