- jks
- 36,304
- 642
Bob, I finally got around to testing that BB Green you returned to me that you were sure caused S9 noise across the entire spectrum when you used it. It's as quiet as a mouse. Absolutely the same as dozens of other BBG's I have here. So unfortunatel…
The admin page backup tab should work well. The user interface is improved over previous versions. Even though this is a complete backup designed to create an sd card to completely re-flash the Beagle, it is possible to access individual files from …
The "IBP" labels were a one-off hack done back in 2016. When the EiBi database was added a few years ago we gained time-sensitive label visibility (start/stop time, both time-of-day and days-of-week). And this was ported to the other datab…
Good catch. I didn't actually watch the video the first time -- too busy. Yes, it has FAC, so the base DRM signal is there (obviously). But no SDC/MSC means there was no digital program material for the encoder. See page 16 on: http://kiwisdr.com/fi…
KiwiSDR no es un software que se instala en una computadora. Es la interfaz web que se muestra cuando se conecta al hardware KiwiSDR con un navegador web. Este puede ser su propio KiwiSDR que compre para usted o uno de los KiwiSDR públicos que figur…
The Kiwi DRM extension is not missing a CODEC. KCBS DRM is known to often transmit silence. There is probably more info here: https://www.drmrx.org/forum/
Probably. Even more so if you can position it vertically (wiring exiting from "top" and "bottom") so that air can convect through the holes in the bottom end plate, up and out the top end plate.
Just so I understand: Starlink by default only has a WiFi connection? Like it has a WiFi router built-in? No possibility to connect an Ethernet cable without this adapter thingy? I was about to suggest using an Ethernet-port-to-WiFi adapter e.g. TP-…
You might mention this on swling.com/blog or www.hfunderground.com/board/index.php Or see if those groups have any more information.
What kind of enclosure did you have this Kiwi-1 mounted in? If it was the old Kiwi-1 aluminum case from Seeed that one is designed to only fit a BeagleBone Green. It is not compatible with the BeagleBone Black. Even though the Kiwi itself will run f…
Ugh, looks like I made a bulk editing mistake, or was half-asleep (common these days). It's always 21xxx.proxy.kiwisdr.com Note the "proxy". Always has to be there. I've fixed the operating manual to say that. But I'm not able to make a co…
Well, as happens all too often on this forum I may not have been told the full story.
I was going to post that. But that begs the question: How do I know if I might exceed 10 to 100 milliwatts on my Kiwi's antenna?
Well, sure, power matters. And size of antennas and how much of the transmit field they are coupling. But I can't definitively say what's okay and what isn't. Is there some reason you can't be 100% safe and just switch the Kiwi out of the receive an…
And.... Another one: https://www.beagleboard.org/boards/beagley-ai RPi form factor. 4-core ARM A53 1.4 GHz, WiFi, USB-C. US $70
I'm sorry, I have to get back to work..
It's not even the clock rate. The BBG/BBB uses a TI AM3359 single-core ARM A8. The BBAI uses a TI AM5729, dual-core ARM A15. Night and day. And the BBAI-64 uses a TI TDA4VM dual-core ARM A72. Because the waterfall is the lowest priority process in t…
One costs $45, the other $150. Want to guess why? 🙄
Are you JOKING? BBG vs BBAI??? I'm going to start fining or banning people for posting this kind of stuff..
How are you doing the comparison? Are you using two Kiwis side-by-side, one running 664 and one running 665? Are you connecting to the one running 665 via a proxy URL? Is there something else different about them? Does one have autorun connections e…
Just follow the direction here: http://kiwisdr.com/quickstart/index.html#id-net-reflash
Is this the new BBG you just purchased or an older one from another Kiwi?
In the next software release the meaning of the SNR numbers is described in more detail. When you mouse over the SNR 32/25 dB text a popup will say 32 dB, 0-30 MHz 25 dB, 1.8-30 MHz The SNR measurement algorithm is simple and by no means perfect. I…
A Debian 11.9 / v1.665 image for the BBAI-64 is now available. See the instructions mentioned above for how to construct an SD flasher card to re-flash your BBAI-64.
Yes, there was a period of time after the Debian guys moved Debian 8 onto the "archive" repo servers that v1.2 got stuck trying to update. I thought all was lost until I figured out that /etc/apt/sources.list needed to be updated (the Kiwi…
Second build shipping begins Monday 25 March. You'll get an email from Shopify/DHL in the next several weeks. DHL has been taking 7-10 days to deliver. https://forum.kiwisdr.com/uploads/757/4ZVKRANF80F9.jpg
Thank you for the confirmation that it worked. Usually I only hear when there are problems! lol
Yes, no c/s docs..
Well.. In principle it should work. But I haven't looked at that code in a very long time. And it's a major hack job. So at the very least I'd need some time just to refresh my memory on how it all works. But there are 10,000 other things that are h…
