- jks
- 36,275
- 642
J'avais oublié ça. Mais le gars qui gère la carte rx.linkfanel.net ne répertorie que les SDR qui reçoivent une bande passante d'au moins 5 MHz. C'est sa politique. +++ I had forgotten this. But the guy who maintains the rx.linkfanel.net map only lis…
The field title says ... (min, ... which is meant to mean "minute".
I'm not going to add individual users to the global blacklist. You can add them to the local blacklist on your Kiwi on the admin network tab. The global blacklist is reserved for known bots that use VPS hosting where large ranges of IPs can be ident…
J'ai envoyé un e-mail au gars qui gère la carte rx.linkfanel.net. Voyons ce qu'il dit. +++ I've sent an email to the guy that maintains the rx.linkfanel.net map. Let's see what he says.
I've already fixed one aspect of this issue (will be included in the next software release). After a page reload all is well. Adjusting the passband edge works when the cursor is dragged anywhere in the grey frequency scale area. When the cursor ent…
It's on the list. But low priority. Because I have to go through Beagle device-tree hell to make it work.
Kiwi-1 with the "external ADC clock" setting (somehow) selected.
directTDoA is a legit TDoA frontend application that actually predates the TDoA extension work I did on the Kiwi. It uses similar TDoA backend code that Christoph developed. And it also uses kiwirecorder to connect to Kiwis to get the GPS timestampe…
As far as I know there shouldn't be any headers (e.g. WAV file). I just copied the code from kiwi_nc.py the best I could. So if that's working then -nc with kiwirecorder should work as well. I could only do minimal testing though.
Yes, email me the admin password and I'll have a look.
Merci pour la précision. Dans la prochaine version, j'ajouterai 10 489,540 comme fréquence FT8/FT4. Mais votre commentaire indiquait 10 149,568 pour WSPR et cela se situe en dehors de la bande QO-100 10 489,5 - 10 490 ? Vouliez-vous écrire 10 489,56…
Non. Les fréquences sont toutes codées en dur. Je peux cependant en ajouter de nouvelles assez facilement. Mais je suis très confus quant aux fréquences que vous pourriez vouloir. Je ne sais rien du QO-100. J'ai donc dû lire à ce sujet. Transpondeur…
They have their own website (http://wsprdaemon.org/) and forum (https://groups.io/g/wsprdaemon/topics) which might help.
Well, looks like I'm wrong about this. If you mess around long enough things change and you get the behavior you describe. Where the passband edges will no longer continue to adjust when the cursor is below the lower red mark in your diagram. I thin…
Well, okay. But this should hardly be news to anyone who has followed the forum for any length of time. We've discussed all these issues over the years in great detail.
Note that when the cursor moves below the passband edge the "popup" that shows the lo/hi and bw frequencies will disappear. And the cursor will change back into a pointer arrow. But you should still be able to continue adjusting the edge w…
After looking at this in more detail (after the other post complaining about the exact same thing). What you describe above should not be happening. Once you mouse-down on the passband edges to adjust the passband width the edges should track as lon…
L'extension WSPR indique « 440 », mais la fréquence de numérotation qu'elle utilise pour la bande de 70 cm est 432 300,75 kHz. Réglez le décalage Kiwi pour qu'il corresponde à votre convertisseur et cela devrait fonctionner correctement. The WSPR ex…
This has been on my list to fix for a long time now. It's annoyingly difficult to fix. There are other methods for adjusting the passband: http://kiwisdr.com/info/#id-user-pbt
No. Use a desktop.
You can see what the current admin password is by doing: cdk gr admin_password admin.json
Not spam at all. It's a legitimate problem/question we see fairly often.
In the file /root/Beagle_SDR_GPS/pkgs/ant_switch/backends/ant-switch-backend-kmtronic-udp try changing: NETCAT_EXEC="timeout 0.2 nc" to: NETCAT_EXEC="timeout 1 nc" This will make netcat (nc) wait longer for a reply from the switc…
According to the kiwisdr.com server you (or something) recently changed the 5-item menu on the admin "connect" tab from "reverse proxy" to "specified IP". Change it back to "reverse proxy" and click the green …
I've been using 32GB cards here recently without problems. This was suspected to be an issue with older versions of U-Boot used with Debian 8. So probably no longer an issue now that everything is Debian 11 based. I just now removed that comment fro…
A re-flash without attempting to save the prior configuration is much simpler (since you can't connect anyway in order to save the config). So no ssh or other connection method is needed. You just follow the instructions on that web page for downloa…
Someone's probably mucked with it. Just re-flash it. You want to update from Debian 8 to Debian 11 for security reasons anyway: http://kiwisdr.com/info/#id-net-reflash
Bump. You know, for the incoming shit-storm.
If your Kiwi is accessible from the Internet please email the URL and admin password to support@kiwisdr.com and I'll have a look.
Duck Duck go has a browser now?
