- jks
- 36,272
- 642
Yeah, you've got some serious cache configuration issues. Look at the browser network tracing below for your Kiwi versus one of mine. The VER file is supposed to return JSON and not be cached. Why are you returning your welcome HTML content? That's …
You must have another browser tab/window somewhere that is re-connecting to the admin page after the restart (before the one that you're showing here). Just do as it says and kick the other admin connection. Then you'll be able to connect and try my…
According to the records on kiwisdr.com you have the large menu on the admin connect tab set to "domain name". Change it to "reverse proxy" and restart.
Almost certainly you're using a sampling station that is throwing a kiwirecorder error for some reason. Like all the channels are full etc. Hold the shift key and click on the green speaker icon to see if you can connect and see the waterfall previe…
Hmm, works for me. What happens when you try this standard setup? http://your_kiwi:8073/?ext=tdoa,DL2NI,oz1aef,f1jek,DCF77,z:5,lat:50,lon:9,sample:15,hosts:,refs:0:8,submit:&keys=y
Was able to test using the real KMtronic-UDP switch just now. And everything works fine. I realize now there is a difference from how the old external antenna switch extension worked. I believe it actively polled the switch for its status once every…
No, you just type "ips" by itself and it will show you the last ip set (name = "ipset-kiwi") loaded from the admin network page interface. Here I've cleared the global blacklist and entered the two entries 1.2.3.4 and 5.6.7.0/24 …
Either notation can be used (with or without a /32 subnet for a single IP address).
Try putting the new address on the front of the local list (not the end). There is this issue that if you have overlapping IP space in the list then the list processing stops at the point of the overlap (e.g. the same IP address duplicated or overla…
Just use the "dog" command. It prints out a few lines with Debian/Linux version info. If you can put it on the network so I can login somehow that would be great. But if your router is shutting it down I don't see how that would work. If i…
Sounds like it picked up a Debian/Linux virus? That is doing a DDoS in the outbound direction? If so, I would really like to understand what's going on so I can prepare a defense for it. We had this problem many years ago until I added code to force…
On the left of the grey frequency scale it says "database: EiBi-A24". This means the content of the DX label area is not coming from the "database: stored", which is the only one you can edit in the admin DX tab. To change which …
I found the guy who has one of these (KMtronic-UDP). He’s on vacation for a bit but will let me debug using it when he returns.
So those values on the admin page may not mean what you think they mean. They are the initial values set the first time a user ever visits your Kiwi. After that they acquire their own values for all the WF settings that are saved in browser local st…
Please see this thread: https://forum.kiwisdr.com/index.php?p=/discussion/3378/in-some-cases-debian-8-is-no-longer-able-to-update-from-github-com#latest If you would like me to check your Kiwi please email your Kiwi's URL and admin password to suppo…
Hi Rob. I'm surprised by that. Since the Beagle is completely in the power path before the Kiwi board it's almost always the BBG that gets blown up. The DC jack on the Kiwi board is just a pass-through to the Beagle (via the P9 header connector). Mo…
You have a configuration issue. Look at the admin connect tab. It looks like you have the 5-item menu set to "Public IP" (from the kiwisdr.com records, I'm not actually connecting to your Kiwi). But under that it must say "Based on ab…
Well, this is the problem. I don't have a Kmtronic UDP, or any antenna switch hardware for that matter (except for Beagle-GPIO). And I didn't write or test any of the antenna switch backend scripts originally. They were all scripts developed by, or …
If you were to duplicate my manual netcat example, and found you did not get the ICMP error, I think that would be a very valuable data point.
I just had to update those instructions a little bit because of some changes to command alias and directory names in the most recent releases. For example, the instructions now say: Note the "or" alternatives below because some command ali…
Yes, those instructions should be fine. I am sorry about this. I am editing this large post now. It is unfortunately completely unknown why Debian 8 is failing with Github.com. And in only certain situations (e.g. I can do it from here in NZ all day…
Okay, but if you've made extensive changes to your dx labels make sure you save them first using the JSON/CSV file save function on the admin dx tab. And if you've made extensive admin customizations that would otherwise be difficult to re-enter by …
Okay, I have to write a long post about this situation as it has now become a huge problem it seems.
With v1.701 this now seems to be working. My thanks to Rene F6BIR for making his Kiwi publicly available that receives the 10 GHz downlink of the QO-100 satellite. Including FT8 and WSPR decoding. Check it out, it's pretty neat: http://f6bir.ddns.ne…
Are you running Debian 8? (Debian version shown on the admin status tab)
Well, I don't know as I didn't write this code originally. But I did a contrived test showing it working: On the Kiwi running the antenna switch change the backend script netcat timeout to 10 seconds. file: /root/Beagle_SDR_GPS/pkgs/ant_switch/backe…
v1.701 should fix FT8/WSPR autorun at 10 GHz.
Please email your Kiwi link/URL and admin password to support@kiwisdr.com (assuming your Kiwi is reachable from the Internet). Also, is this Kiwi located in Europe? We've been having update problems with those that are still running Debian 8.x locat…
Dans la version 1.700, tout est là. Après avoir défini le décalage de fréquence sur 10 GHz, les extensions FT8 et WSPR afficheront les entrées 10 GHz / QO-100. Les entrées pour celles-ci apparaîtront dans les menus d'exécution automatique, quel que …
Extrait du fichier CHANGE_LOG : « FT8/WSPR : ajout des fréquences satellite QO-100 aux menus d'extension et d'exécution automatique. » +++ From the CHANGE_LOG file: "FT8/WSPR: Added QO-100 satellite frequencies to extension and autorun menus.&q…
