- jks
- 36,235
- 639
                The data for those come from these files. See if you can open them directly from your browser. If not, find out why not (e.g. look at browser console for error messages) http://tdoa.kiwisdr.com/tdoa/files/kiwi.gps.json http://tdoa.kiwisdr.com/tdoa/r…
                There is never any "one size fits all" solution when it comes to filtering. If you're serious about 630 m, where you don't want any attenuation of weak signals, you should never be looking at a full MW bandstop filtering solution. You're n…
                There's always KMTronic. No coax connectors though. Just Phoenix contacts.
                All the currently supported switches, including Ethernet-based switches, are listed here: https://github.com/jks-prv/KiwiSDR/tree/master/pkgs/ant_switch There is not a proper pointer to that in the base documentation, so I will fix that. Thanks.
                I think it was finally removed from the Android app store. But I saved a copy at: kiwisdr.com/files/gavtrok.apk (or possibly KiwiSDR2.apk -- there are two .apk files and I can't remember what they are and my notes don't have any info about them) The…
                KiwiSDR 2 radios are available again in our online store: https://kiwisdr.nz Thanks for your support.
                This work is nothing short of amazing. Great job. Also, thats for measuring the current of the FPGA 1V0 rail. I had always wondered about that. I would not have guessed such a low value. It's true that none of the FPGA logic switches above the ADC c…
                Perhaps they are asking you to add a connect time limit to your Kiwi. For example, I was not able to connect because all the channels were busy. And I see from your entry on rx.kiwisdr.com that you do not have any time limit setup currently. A time …
                We're also adding a washer to one of the case screws and recommend that you add a ground wire to the case if your antenna connection does not provide a good ground. It is important to provide a ground path for any static charge dissipation.
                One of the units had the CPU board nearly disconnected (apparently due to heavy DHL handling). It was just opening the cover and pressing the board to the connector, but it is worth checking with every unit when receiving. —Kauto OH2LFM David, ZL2B…
                Friendly reminder that I am more than happy to fix this problem for you. I don't want anyone out there to feel their Kiwi is toast due to my stupidity. This situation is entirely recoverable. I've fixed 87 of them now (by hand, over the net). Takes …
                It depends on what you mean by "log" as there are some subtle differences. Not all messages appearing in the admin log tab are recorded in the Linux syslog. The ones prefixed with an "L" are. They should be recorded in /var/log a…
                The admin page, config tab, colormap setting only applies if no override exists in browser storage from a previous visit to the particular Kiwi. Usually the first time you visit it (or after a storage/cache clear). If it's starting with csdr just ch…
                Well, except that's not happening anymore. For whatever reason (and there are many). And that makes it tough justifying major financial and time commitments to future projects when the likely uptake is now very uncertain.
                Most of your problems would probably disappear if you got rid of that awful Ethernet-over-powerline RFI generator and replaced it with this on the Kiwi end: TP-Link TL-WR802N Also, reduce the Ethernet speed to 10 mbps on the admin network tab.
                Although I should add that despite Martin's well-chosen words "extremely difficult trading environment" we still have some cool stuff in the pipeline. We haven't given up.
                Let me ask our manufacturer if they can take some off their reel so we can send to you. Please send your postal address (not DHL parcel address) to support@kiwisdr.com
                Really? From TI's online store. 497,630 in stock. https://forum.kiwisdr.com/uploads/551/EQFH9ME0S9BD.png
                Do you have your own extension that requires this? My impression was that, aside from the antenna switch (which is of course now integrated), that no one ever used the external extension interface.
                Thanks. Unfortunately things are not good on our end. And haven't been for a long time. So it's always nice to get a positive message every so often.
                Grrrr.. https://forum.kiwisdr.com/uploads/159/4V38VXDDXXD3.png
                Using an online voltage drop calculator you will find that a cable like that will drop a 1.5A load (possible Kiwi peak current at startup) to 4.6V. Below the startup voltage the Beagle will allow (roughly 4.8V). That assumes a copper conductor (not …
                But also, a USB-C to DC barrel plug cable alone will not work as mentioned in the first post here: https://forum.kiwisdr.com/index.php?p=/discussion/3009/quiet-switch-mode-power-supply-smps-for-kiwisdr/p1 You need a USB-A (note A) to DC barrel plug …
                Yes, 5 feet is much too long.
                What kind of cable are you using? Don't use the USB-C to DC barrel jack cables from AliExpress as mentioned here: https://forum.kiwisdr.com/index.php?p=/discussion/comment/17084/#Comment_17084 Also, in general, if your cable is too long, or has too …
                Good catch! I think I have this fixed now and it will be in the next release. Thanks
