hobergenix
- hobergenix
- 17
I set it at 5.1 for now. The power supply has two DC output jacks and I just purchased a second Kiwisdr and will run both on the same supply. I did look up some USB specs and found the min and max voltage stated to be 4.75 to 5.25 Vdc.
Thanks for the info. This will save me a few dollars in getting my second KiwiSDR up and running. I think in the early development a BBB was used and probably switched to a BBG to save a few dollars. I bought my first KiwiSDR kit on the MassDrop web…
I will have to look at the specs on the board. I am not sure if having the extra electronics on the board for the HDMI display might cause any RFI problems even though no display will be connected. The version of my board dose not have WiFi. I alrea…
