foxd
- foxd
- 68
- 2
Alsointerested in one.
I got it. Apparently an accidental save changed all the Service/Broadcast entries on the Band Plan to Service/Unknown. Changed them back to Broadcast and it is working properly. BTW, I love this radio and congratulate you on an amazing job.
Browser: Google Chrome Version 100.0.4896.127 (Official Build) (64-bit) KiwiSDR version: v1.510 My own KiwiSDR, not shared publicly because Comcast would make me pay to do that. It was working this morning with the same version. Checked another Kiw…
I opened the Javascript Console and found these errors: kiwisdr.min.js:40 Uncaught TypeError: Cannot read properties of null (reading 'o') at setup_band_menu (kiwisdr.min.js:40:94065) at panels_setup (kiwisdr.min.js:40:139519) at wf_init (kiw…
I too have been having the scans to pause on a frequency and just sit there. For what it is worth I've found hitting the "test" button will cause the scan to start again. It doesn't seem to matter if I'm using the computer or just lettin…
I opened the unit up and put in the plastic washer. It did look like I could have used a second plastic washer on the plastic stand off to match the metal ones. Plastic standoff is in the right position. I did forget to check the antenna screw te…
The enclosure was delivered today and has been assembled. How critical is the one nylon washer? I didn't find it until I opened the bag with the feet.
I got the shipment notice and it should be delivered Wednesday.
While I haven't gotten a shipment notice yet, the Online Components website has updated the number of enclosures they have from 7 to 45. Price $15.85
Yesterday I got a notice from Mouser that the enclosure I had ordered is discontinued. However Online Components listed it in stock and said it would ship today. BTW, I strongly suspect that Online Components and Master Electronics are the same co…
That did it, this time for sure!
Well, within an hour the site was blocked again. I called and have been deserted on chat. (The chat window has been open all night.)
Everything seems to be working.
After much digging I found two IP addresses are being blocked, one is for kiwisdr.com. I don't know what the other one is, but I suspect it is the github site for software updates. I am chatting with tech support now.
I've talked to Comcast technical support which so far has been of no help. I was supposed to get a call from their more advanced support. So far no call. Tracing route to kiwisdr.com [50.116.2.70] over a maximum of 30 hops: 1 1 ms 1 ms 1 …
I am strongly suspecting that Comcast is blocking the site for some reason I will explore further.
C:\WINDOWS\system32>ping kiwisdr.com Pinging kiwisdr.com [50.116.2.70] with 32 bytes of data: Request timed out. Request timed out. Request timed out. Request timed out. Ping statistics for 50.116.2.70: Packets: Sent = 4, Received = 0, Lost = 4…
I'm in Bloomington, Indiana USA and still can't reach the site. https://www.isitdownrightnow.com/kiwisdr.com.html This has been going on for several days. I was able to reach the site by just now downloading and using a Tor Browser.
