fabrys
fabrys
1,053
1
  • https://forum.kiwisdr.com/index.php?p=/discussion/comment/13635#Comment_13635 ... yes I had checked on another IP Reverse site and anyway they are all 3 IP "Vultr". I don't know whether to report to the ABUSE email [OrgAbuseEmail: abuse@c…
  • ... I'm sorry if it's a repetitive question, but I can't always follow the forum information, which is sometimes too technical for me, but these kiwirecorder.py users should be blocked? I state that I have been back online for just 2 hours Thu Mar 1…
  • https://forum.kiwisdr.com/index.php?p=/discussion/comment/13600#Comment_13600 if you want to hear it, it is now broadcasting on the 3.607 Mhz frequency
  • ... it looks like the MIL-STD-188-141A or Automatic Link Establishment (2G ALE), except that it is not decoded, it would seem a type of encrypted audio rather than a digital only transmission and ends the transmission with a series of morse signals …
  • perfect. thank's for your job.
  • excuse the curiosity, but while we are on the subject, to modify or add portions of band on these labels, https://forum.kiwisdr.com/uploads/048/V3V5TEOCMYF6.jpg what is the procedure, I do not know if it is explained in the instructions but I have …
  • To sum up: The dx.json file should not be damaged if I understand what is reported in the progression of the starting commands of my KIWI, as highlighted below, it is the only line I have found that shows the dx.json. Tue Mar 15 00:48:52 00:00:31.…
  • https://forum.kiwisdr.com/index.php?p=/discussion/comment/13557#Comment_13557 7,700, maybe I'll get there in 4 or 5 years :-) however, as for the previous post to yours, you keep talking to me about "dx.json", but the answer is always the…
  • https://forum.kiwisdr.com/index.php?p=/discussion/comment/13556#Comment_13556 Thank you for the information, but I really don't know how to access the directory and perform the operations you suggest. I have no such experience.
  • https://forum.kiwisdr.com/index.php?p=/discussion/comment/13551#Comment_13551 No, I have not received any messages, as mentioned in the post above it is the only window button that is not accessible, I do not know if it is a problem of the last brow…
  • https://forum.kiwisdr.com/index.php?p=/discussion/comment/13550#Comment_13550 Yes I have to add it as new otherwise it doesn't change it. No, I just tried to change the type of reception from AMN to AM but the mouse kept turning only on the tag cha…
  • ... yes, but it is a real shame if not for everyone, it certainly is for fans of "wefax" reception. Being one of them, I take this opportunity for an update regarding RBW 41 - Murmansk - Russia. In recent months I have followed it quite co…
  • http://forum.kiwisdr.com/uploads/669/BC5W5T9GDFSP.jpg For news, this time it is the end of the broadcasts from March 31, 2022 as announced by "JFW" IWATAKI FISHERY RADIO which broadcasts on the same frequencies as "JFX" Kagoshima.
  • Good morning and happy holidays. I would like to bring to your attention the following IP: Fri Dec 31 13:04:25 12:16:07.735 012. 1 L 216.00 kHz am z7 "37.73.49.143" Ukraine (ARRIVED) RX1 (37.73.49.143, Ukraine) 262.82 kHz am z7 0:0…
  • when they put me online again maybe I change the port too if it is not a complicated thing to do. But it always remains to understand the reason for these continuous attacks, what is the real reason? Fabrys
  • I believe that too [let's go back to writing in English for everyone else] the reason, I would like to know only the reason, considering that my kiwi is in free access, and I don't remember having created problems for anyone. Maybe if I had some m…
  • http://forum.kiwisdr.com/index.php?p=/discussion/comment/12988#Comment_12988 ...non ne sono del tutto sicuro mi ha scritto John S. stamani comunicandomi di avermi messo fuori dalla rete proxy reverse in quanto l'ultimo attacco che ho subito, quello…
  • http://forum.kiwisdr.com/index.php?p=/discussion/comment/12985#Comment_12985 ...vorrei sapere quale cazzo di problema hanno verso il mio kiwi [scrivo direttamente in italiano così posso esprimere tutto il mio disappunto]
  • http://forum.kiwisdr.com/index.php?p=/discussion/comment/12946#Comment_12946 I made the report. After two days of peace following the last update, the attack began again. Fri Dec 24 19:21:20 18:33:05.809 0... L IP BLACKLISTED: 35.202.193.127…
  • Good morning and happy holidays. .. this morning after previous IP blacklisting 120.36.245.22; 120.36.244.189; which access on my Kiwi and remain stable for the entire time allowed by the connection on a frequency in AM mode where there are no trans…
  • ... also on mine it is like this but and I don't think I'm wrong it was already like this before the last update. http://forum.kiwisdr.com/uploads/532/8LVGJ5NGFXUR.jpg
  • ... as you can see from the lines below, which are from a minute ago: Tue Dec 21 18:26:48 00: 28: 52.493 0 ... L IP BLACKLISTED: 34.138.64.141 Tue Dec 21 18:26:48 00: 28: 52.498 0 ... CONN: 127.0.0.1 X-Real-IP 34.138.64.141 Tue Dec 21 18:26:48 00: …
  • Hi Stu .... thanks for the tip, I'll do some tests hoping to get rid of these annoying accesses. Greetings Fabrys
  • http://forum.kiwisdr.com/index.php?p=/discussion/comment/12901#Comment_12901 .... yes you are right, I did not notice when I posted this post because I had not opened the ADMIN / LOG page, then when I made my post on your post I found that the probl…
  • this is also my problem, I am attaching a pdf with the data. http://forum.kiwisdr.com/uploads/034/L6JNW2XLW4EU.pdf Fabrys Update: .... the device blocking problems continue. Tue Dec 21 11:36:32 00: 35: 45.307 01 .. 1 L ### SECURITY: NO AUTH YET:…
  • Good morning, I have a question about the blacklist. On my Kiwi, a few weeks ago I had an IP address 120.36.245.22 connected h / 24 on a single am frequency where there are no transmissions, after performing the Kick I noticed that 7 seconds maximum…
  • >It could simply be that the server was busy at the time. >I'd try manually updating again. >Regards, >Martin .... I've been trying since this morning, that is since I posted the first message .... but the result is always the same, this…
  • Good morning..... after updating to version v1.462 on the update page this error message appears .... what is the problem? Considering that it is the first time that the following error appears !! http://forum.kiwisdr.com/uploads/908/4CELB8UDVFL3.…
  • .... I looked for the frequency in the fax file and I think I have identified it under Murmansk, while the broadcaster in question should be (Odessa in Ukraine or Sevastopol in Crimea), unfortunately the frequency / transmitter is not reported even …
