f6bir
- f6bir
- 213
- 1
thank you all well understood
Hello JKS, Thank you for answer, in the log ml ms mu do not appear the WSPR decoded stations as in the admin current log. I can see them on WSPRNET web site, but I would like start an autorun wspr without web connection for a while and to have a …
Hi Martin Thank you for answer, my idea was to do that with a short-cut to view immediately the SNR difference between antennas like using WSPR or FT8 mode. (antennas are loop, dipoles, GP R7 and miniwip, on 20m miniwip seams better ) Actually I u…
Thank you for your information Rene f6bir
after update release v 1.285 all is working well again I dont understood what appening.
Hi jks Thank for replay ...I will wait for that
Thank you for info that is the answer root@kiwisdr:~# file /var/log/user.log.1 /var/log/user.log /var/log/user.log.1: ASCII text /var/log/user.log: ASCII text root@kiwisdr:~# regards
