du6_pe1nsq
- du6_pe1nsq
- 78
- 7
im getting connection refused on your URL ... It looks to me that port forwarding isnt working correctly?
Thanks, I see it listed now again ... I was using your reverse proxy before, but at times that was slow. Hence the reason to put it direct ...
yeah, i use a $5 VM there to route my traffic to my internal network (not only for the Kiwi) because of the provider grade NAT ... could you make an exception for just that IP? its fixed ...
took it apart again, put it in the housing and reconnected all wires ... All fine still, must have been a bad contact or something ... or gremlins Thanks for all the help, im back in the air! Cheers, Rick
ive got it fully running with debian 10 and my config restored ... Yeah im sure the pins were correctly alligned (and it shows, its not destroyed :) ).... Let take it all apart again and see what it does. I need to put it back in the housing as well…
hmm, took everything apart and put it back (kiwi and beagle), which i have done before ... And now its running ... I need to play around a bit more (with the risk of breaking it again), maybe a bad contact on one of the pins?
It was there, edited the post... might not have updated for you ... I wish i had, that would have been my first action ... sadly i dont have... Anyway to get more debug out of a manual connect string maybe? is there something like lsusb for spi?
same as in my previous screenshot: https://forum.kiwisdr.com/uploads/846/I4SBK0P4H78F.png
Yes, same after a power cycle ... https://forum.kiwisdr.com/uploads/478/9OGO5DFCLTKN.png Not sure if this output helps: https://forum.kiwisdr.com/uploads/863/6M2FD6J1TIZP.png
Ok thank you both ... I missed the root thing with debian 10, so let me try that again tonight when I have some time to sit down for that ... edit: @jks ok im in debian 10 now. Im seeing the errors as when I restore my original config. i did an up a…
thanks for the reply. Yes i had to press the boot button to get it to load 10. After that the lights will go off, i remove the power and SD card and boot. DHCP will provide the IP (i have a reservation for the mac) and I can SSH to it, but it wont …
It seems to do the trick though ... I changed my hostname as well to get rid of all those connections attempts. So for now it seems to be ok again. Just waiting for a new powersupply, since the old one seems to be on the verge of breakdown. Thanks …
@jks I think the update worked .. I now see in the log: SND BAD PARAMS: sl=15 83|69|84 [SET autonotch=0] ip=47.242.241.144 #################################### And they are being kicked off. Sadly, i think my power supply is dying ... so need to a…
http://forum.kiwisdr.com/index.php?p=/discussion/comment/11830#Comment_11830 cheers ... ill try if I keep on having issues. So far I have not seen them back ...
http://forum.kiwisdr.com/index.php?p=/discussion/comment/11827#Comment_11827 Hi John, Yes on everything ... you see them in users and admin page as DRM and existing connections stop responding, with all connections at the end timing out (ping still …
Hi Yuri, Yes that would normally be easy. Im only on a provider grade NAT, ie no public facing IP and im using the reverse proxy service from John. So I dont have access to firewal rules. All i have are the iptables on the kiwi itself. I tried addin…
Thanks John ... not sure how i missed that!
yeah i know how frustrated this can be ... Ive got a tail running and cant confirm that its not over haha Mar 9 04:37:43 kiwisdr kiwid: 1d:14:36:13.631 0... IP BLACKLISTED: 47.74.181.109 Mar 9 04:37:43 kiwisdr kiwid: 1d:14:36:13.635 0... …
Same here ... Seems to be spreading now to korean IP's a well. Latest here is 13.125.229.253 ...
Thanks for sharing ... Yes that was the reason for starting this topic. I cannot imagine we are the only ones having these issues
lol, yeah i feel you ... its very annoying. Unfortunately my ISP changed the setup here, so we have to deal with provider level NAT. Meaning I cant get any traffic to my router and I have to use the reverse proxy service from John. So I cant filter …
Hi Stu, You are absolutely right. I found the blocks which they are part of, so its easy enough to block the whole thing, just didnt want to go to that extreme (as it seems to be legitimate ISP), but if it continues like this i will certainly do it…
hi Stu, Unfortunately I have the reverse proxy service, otherwise I would have done the same. Just notice right now a new IP address again, looks like an endless battle ... It would be nice to recognise the pattern of connecting and block them base…
so all ok now, no need to be a HAM? Only need to authenticate (with all the hackers going around maybe not a bad idea to start with) ...
looks to me that there is a technical issue.... i now get error 404 when i click on login (and im a licensed amateur) ... Ok forget that, there seems to have been change on the website and I didnt refresh ...
While I was away we had an internet outage, which was fixed before I came back... So I never expected this to be an issue, but it is ... Something has changed on my provide side, I just cant figure out what yet ... Packets just dont arrive at my fir…
Hi john, yes thats correct ... Ok let me investigate.... I really should get rid of that custom domain and use my regular ... Ill report back later ... Cheers, Rick
