XPloRR
Hello,
I read your message just now here.
Could you enter your serial number in QiwiQ?
Sorry for the delay,
Johan
- XPloRR
- 315
- 25
@jks I noticed a strange behavior of SQUELCH (could be my ignorance). You can simulate it as follows (also in Kiwi web interface): select server f.i. http://g8ure.ddns.net:8073/?f=10Mamnz10 select a strong signal: f.i. BBC at 693 kHz. change the SQ…
I try to figure out the modulation of certain frequencies on this VHF/UHF server to try to support it in QiwiQ: http://hasenberg04.proxy.kiwisdr.com:8073/?f=10Mamnz10 If you tune f.i. to 120000 kHz you can hear a distorted music channel. There are m…
Thank you @jks for your useful information. I already got information from another contact that they (probably) are clones. So I don't have to bother debugging them further. About the VHF/UHF servers: you do not need to look in the code, I already f…
@jks and others: I noticed that QiwiQ cannot connect to certain servers, like: http://wessex.hopto.org:8075/?f=10Mamnz10 Strangely I can open the socket, but no data received. What could be the reason why they refuse to connect? Timing problem? Ano…
New version of QiwiQ released: 2.05.20 • New FFT Auto maxdBm adjustment: auto-adjusts the maxdBm value to the maximum signals received (always active) • New FFT Auto Noise-Floor mode: auto-adjusts the noise-floor value (switch on/off and set offset…
New version of QiwiQ released: 2.02 • New interface with both Waterfall and FFT Spectrum on the display • FFT spectrum has a scaling grid and a dBm measurement • Selection between Color and B/W FFT graph • Band buttons are available via a dropdown s…
@ve6jy thank you for your feedback. I also like those old receivers like the Sony ICF2010 and others. It is already possible to enter your own kiwi server url: click on the server list and enter your url in the field and click Select. I will take no…
@LIN_in it is now possible in version QiwiQ-1.45.04 to enter your own Name/CallSign instead of the automatically assigned fingerprint (via settings).
@n6gn Thank you for your valuable feedback! First, a question: do you use a spectrum display on a radio in the same way as on a measuring device? I’m not a specialist in this matter, but I would say that a spectrum display on a radio is used primari…
@LIN_in that is an interesting suggestion to add the callsign. I had it early on my todolist, but somehow it got forgotten. Will implement it in the next version. You will be able to enter your callsign in the settings. if you leave it empty the exi…
Thank you for your feedback! The app by Marcus Roskosch indeed looks nice. It was my explicit intention to bring forward the buttons I use most frequently from the kiwi-submenus. This does indeed reduce the available screen space, but when I use my …
New version of QiwiQ released: 1.45 • Auto-Station detection when clicking SET button (repeat for multiple matches) • Bug fixes + ui-improvements I have implemented an automatic station detection feature in QiwiQ using the AOKI Shortwave Frequency D…
New version of QiwiQ released: 1.44 • FFT Spectrum Display with adjustable smoothing (averaging adjustable in settings) • Squelch implementation for NBFM • Waterfall color improvements • Bug fixes + ui-improvements Download at: https://bit.ly/3I49Lf…
@dl7awl it is now possible to specify/select your private/local Kiwi server.
New version of QiwiQ released: 1.43.03 • Scan function: auto-cycling through the frequency memory list in the current modulation mode (scan-Interval adjustable in settings) • Audio compressor switch moved to settings • You can now select your local/…
New version of QiwiQ released: 1.42.00 • Option to show frequency memory labels on the display (via settings) • Tune by cycling through frequency memories in the current modulation using <> when waterfall is off • bug fixes + ui-improvements T…
barneyuk I changed the knob behavior so knob sensitivity is now adaptive based on both the finger travel available in the swipe direction and the remaining value range in that direction. Swiping from the knob start position all the way to the screen…
I understand your point. What I may consider is changing the swipe sensitivity. I could make it so the the full range can be reached in one swipe, without lifting your finger, but then I may loose resolution. I will do some checks, to see if all val…
@barneyuk the reasons why I prefer knobs above sliders are: they take less space on the interface, they have a higher resolution when changed, they resemble classic radio's and are more aesthetic imo.
@jks I noticed that squelch is not working on NBFM? Is that a bug or by purpose?
@n6gn thank you for your feedback. I also read you comment on the coffee registration. Normally you should have been returned to a page with your registration key after PayPal. I have just mailed your key. @barneyuk did you know you have to simply s…
@F5AFY Thank you for your feedback. You are right. Zoom 14 seems to be the max zoom level. I will correct this and clamp zoom between 0 and 14. About the CW frequency I am still in dubio. Technically en conventionally you are right, but logically an…
New version of QiwiQ released: 1.41.10 • CW(Morse) decoding implemented • standardized signal S-meter implemented: S1-3-5-7-9+10+20+40+60 (values above S9 should be read as S9+..dB) • backup favorites: import/export frequencies from/to clipboard • s…
Thank you, I will have a close look at it to understand it first. The problem with the s-meter is solved, I will implement a standardized S-value. S1-3-5-7-9+10+20+40+60 (values above 9 will have to be read as S9+value), so S20 means S9 + 20 dB. Sta…
I consider replacing IQ with SAM then. Will see what I can change to make keys more visible, but want to keep the interface stylish, not cluttered with different colors. Another question: is there a method or socket to decode cw (similar to drm ext…
Another question: has anyone ever found an FM signal on the shortwave bands? What is most common on shortwave: NBFM or NNFM?
New version of QiwiQ released: 1.39.19 • new audio processor v.19 • DRM support with stereo • IQ support: rendering I+Q signals to audio • disabled audio-flush when changing volume, mode, ... • avoid audio clicks when clicking buttons • correct back…
What I don't understand however is what is the practical use of IQ in a (mobile) client, since IQ is not a modulation, it is another way of presenting the audio by the SDR server in a real and imaginary part (I=in phase component, Q=quadrature compo…
Thank you! I understood. This is as I suspected.
I checked, but IQ packets seem to be in mono (real+imaginary part). I did some raw testing and I suspect that DRM is not presented in IQ format as a real+imaginary value, but as a pcm encoded stereo signal (different from IQ). So I suspect: IQ forma…
