XPloRR
Hello,
I read your message just now here.
Could you enter your serial number in QiwiQ?
Sorry for the delay,
Johan
- XPloRR
- 315
- 25
@jks how can I implement the password logic? What is the password protocol? Do I receive a password message in the SND socket after 10 minutes? Should I then send something like: SET auth t=kiwi p=# ipl=Mypass ?
New version of QiwiQ released: 2.05.59 • Fix for clean install bug (since proxy.kiwisdr.com servers have missing port) Users who upgraded QiwiQ did not experience this bug, only clean/new install of QiwiQ had this bug. Download at: https://bit.ly/3…
Problem found and fixed :-) Have to compile and will release shortly. @jks @W0BEV let me know if it is fixed. Also license key entry problem should be fixed now.
Strange. Problem is that it is difficult to debug when I cannot replicate the problem. @jks if I understand you well, it runs ok on your phone, but not on your tablet, correct? What are the Android versions on both? What is the last version that wor…
New version of QiwiQ released: 2.05.58 • Use of loadbalanced github project urls (possible update delay) • Different "fetch" method of loading resources @jks @W0BEV I created this release to try to fix your latest problems. Let me know if …
For those who have problems opening the server list. If you have the problem, can you check if you can open this file on the phone/device where QiwiQ is installed: "https://raw.githubusercontent.com/xplorr/shortwave-schedule/main/kiwiservers.j…
It seems very strange that you have the same behavior on 2 Android phones. I do not have enough information to check out your problem. If you could send some screenshots of what is happening, could clarify some things. Are your Android phones recen…
New version of QiwiQ released: 2.05.57 • Fix for proxy.kiwisdr.com servers with missing port • Bug fix in v.2.05.56 This fix does not yet support the newly announced proxy load balancing (proxy2.kiwisdr.com). Download at: https://bit.ly/3I49LfD Fe…
Update to the 8073 proxy.kiwisdr.com problem. @jks I spent 4 hours trying different scenario's to fix the problem, but it seems It cannot be fixed. The problem is that I use websockets (ws://). http:// request are auto-redirected to the server behi…
@jks Regarding the 8073 proxy.kiwisdr.com problem. Indeed, I noticed that the server directory now has many (proxy) addresses missing the port number 8073 (I believe it is a recent change). Would it be safe if I add :8073 to the url as an an easy fi…
@jks thank you for your answer. So if I understand you correctly, I have no way of getting informed outside the forum if someone posts in the thread? If so, may i kindly ask anyone who has an urgent question/bug and I do not react within a few days…
@jks meta-question: Since I do not have this thread constantly open, I have set e-mail notifications, but I do not receive notifications via e-mail. What is the problem? Below are my settings: https://forum.kiwisdr.com/uploads/044/VA4NWC2PCB21.png
@va3xa I will have a look at your server 21263.proxy.kiwisdr.com:8073 Update: your statement that QiwiQ cannot open ...proxy.kiwisdr.com servers seems not correct. I tested several servers and they work, including your server: 21263.proxy.kiwisdr.co…
@ve6jy I come back to your earlier request: "I'd also like to have the ability to edit the 24 band buttons, to have them go to frequencies of my choosing and have the labels reflect that." I have been thinking how to integrate this, but I …
AGC has not been changed in the latest 5 versions. The AGC parameters used are: SET agc=1 hang=0 thresh=-100 slope=6 decay=1000 manGain=50 Perhaps @jks could advise to use other default AGC settings.
New version of QiwiQ released: 2.05.52 • Support for legacy servers (version <= 1.690) • Fix while switching servers • Fix offset bug on legacy servers • Bug fixes + ui-improvements Download at: https://bit.ly/3I49LfD Feedback/bugs welcome!
My new version seems ok (will release soon after some more testing).
Sorry my mistake, was testing with another server. Can you check the log for a frequency of 198kHz and check if you get a "API: decided connection is OKAY" (or something) at around 14:22 UTC?
Can you give me your server address again, to make sure we talk the same server?
studentkra I just found a free slot and the stream continues. Can you check the log for a frequency of 198kHz and check if you get a "API: decided connection is OKAY" (or something) at around 13:10 UTC?
@studentkra thank you. But I was testing with a new version that should present QiwiQ as a "real Kiwi app". Could you disable it again so I can test?
@NU6F can you send me your server address so I will have a (debugging) look at it. ps. I am currently testing a new version to support legacy servers (version <= 1.690). Could be the reason. Let me have a look. Update: if this is your server: htt…
@jks you are right to correct me. Excuse me, It was my mistake. I understand the purpose.
Update: I found the solution to be accepted as real Kiwi-app ... [jks: Edited to remove explanation of how to bypass some of the bot countermeasures. We don't know who's reading here do we?]
Ok sounds plausible, but how should QiwiQ present itself then as a Kiwi app (since basically that is the purpose of QiwiQ)?
@studentkra can you explain why I receive a message "MSG too_busy=0" after 5 or 10 seconds of SND data? How can I avoid this? Has it something to do with the client version or a message you expect and not receive?
https://forum.kiwisdr.com/index.php?p=/discussion/comment/21593#Comment_21593 I understand what you mean, but the same field can also be used for a free Search field, so I cannot set both.
@jks is there any logic behind this: From certain servers I notice that QiwiQ receives a message on the SND socket after about 10 seconds or so: MSG too_busy=0 And the socket closes. However if I access the server using the Kiwi Web interface, I do …
New version of QiwiQ released: 2.05.44 • Private servers can now be added/deleted as favorites ("Select" button replaced by "Add" button) • Fix for large "text size" setting in Android • Fix for big screens • More robus…
New version of QiwiQ released: 2.05.36 • Support for UHF-, VHF- and all servers starting above 32 MHz + extra frequency digit added: 0-999999.99 kHz • New "Selective Preset Scan/Step" mode (always active): Scan/Step only search results of…
