- WA2ZKD
- 16,165
- 14
the red would have been green if you had a valid SN so your board has an issue. If you have read the physical "sharpie" number handwritten on the kiwi cape, enter it otherwise 4730
an example... 2022-09-09 07:56:54,191 pid 26783 resampling from 12001.1 to 12000 Hz (ratio=0.999904)
Some are daunted by the kiwiclient tools Here's a simple line that will get you audio from your speaker ./kiwiclientd.py -s jimlill.com -p 8073 -f 1180 -m am -L 100 -H 3000 --ncomp --resample 44100 you can send that to something like Audacity to re…
I wonder if you could use kiwi_nc.py and kiwirecorder.py from the kiwiclient tools to do this external to the kiwisdr itself? sox might be able to help http://sox.sourceforge.net/Docs/Features
I have used kiwirecorder --resample successfully to grab wav files for standalone wprd testing.
what is the URL for your RX?
https://portforward.com/arris/dg3450a/
I can't help you today.... but you might post what router you're using here. Whoever helps, will need to talk you through Port Forwarding.
I think you somehow got that develop branch in your system and it likely messed things up. Did force update from the admin page not work?
what action did you take to get that output?
sometimes adjusting the AGC will help... google AGC settings for CW.. fast attack, short decay type settings.
https://www.amazon.com/HiLetgo-MAX3232-Converter-Module-Serial/dp/B00LPK0Z9A IGNORE
are the older BBAI no longer available?
are the exe files created with pyinstaller?
you might look at this: https://www.blackcatsystems.com/software/kiwiSdr-sound-client-virtual-audio-device.html
what string do you feed to kiwi_nc cli args that is
jimlill.com:8088 correctly breaks down the eu bands rather than merge or ignore them
his yaml code was for one value for each option. In this case, you have "n" values... the comma-delimited cli ones. for each option.
https://forum.kiwisdr.com/uploads/379/DCGLVERFELRU.png
Jim, but running Debian 9 or 10? If D10, does your log say ### using SPI_DEV /dev/spidev0.0 or /dev/spidev1.0 ? 9.0, my oversight in replying
putting a piece of tape over the "evil" pins on J9 is a good measure. Kapton tape a good choice if you have it
I have 2 BBAI systems running latest code without issue.... FWIW
Seems that many ISP supplied modem/routers have "issues". Why not just add a "real" router after the ATT one and handle it there.
If the pole was wood.... while listening to your radio, rap the pole with a small sledge hammer and listen for a change in the noise. Even better on a rainy day!
Would it be possible to add a "Update Window" choice in a admin tab so we can select a preferred update time? Currently mine occur sometime around 0800Z I think which is when I often get up to look at DX etc.
which cap did you use in the notch?
if there are connections, does it get skipped like an software update would?
when does the blist thing occur?
There is nothing that says you can't use multiple caps in parallel. Also, NP0 is equiv. to C0G https://uk.rs-online.com/web/p/mlccs-multilayer-ceramic-capacitors/1220709
if you use ceramic, you better use NPO type as they are stable
