- WA2ZKD
- 16,165
- 14
running new WSPR locally, I observed the server restart on its own, once after 30 or so mins.
A handy tool for calcs http://www.1728.org/resfreq.htm
One of these and a 100 uH or so inductor would do it https://www.amazon.com/Capacitor-Variable-Single-365-Rotation/dp/B00EQI9K9O
I am building something similar to Martin but for the lower BC frequencies. Currently, I have a HPF
I like to run one channel 24X7 on WSPR or at least when I am not using it for other listening, so that would be a great enhancement!
http://www.dxing.com/tnotes/tnote06.pdf
You have 2 options.... 1) add a AMBC High Pass filter which would attenuate everything below 1.7 MHz 2) build a Notch filter for 540 KHz
I bought one of these and it's very clean... it didn't fix my 3600 KHz buzz however, confirming my POV that it is coming in the antenna.
I knew Color Burst! My next move is shut the whole house except for the Kiwi and see :-)
The exact freq is closer to 3585.5
Yep, I saw him again this morning. So have logged him at both end of the grayline now
MELP Digital Voice is also sent via those 110 modems at rates from 600-2400 bps
Websocket can be an issue for users that are behind corporate firewalls. I know <sigh>
I used to do the Static IP dance on a lot of stuff and my friends told me better to let the router handle it. Most (all?) routersallow you to lock the MAC to a fixed IP address. That way a device like the KiwiSDR will get the same address DHCP'd to…
VK6XT is about 500 km east of the antipodal point of my city, Rochester NY
I note now that this has already been requested!
Chrome on Linux works fine with v1.49
Seems like deleting stuff might be easy..... looking at lines like these, just delete a whole line, correct? ,[10253.75,"CW","FSK","FSK-CW%20ID,%208PM",{"WL":1}],[10285.00,"USB","FSK",&…
More testing for interference....* added Type-43 ferrites on all cables. * terminated antenna input in 50 ohm, things look very clean on spectrum analyzer display and with a narrow waterfall * I must have lucked out, as a I see no evidence that 5V …
I stopped using static IP in my devices and instead use MAC/IP locking in the router.
Too bad you can't get PPS from the GPS chip. That would give you uSec accuracy. Maybe your technqiue yields the same though. -Jim
The GPS time displayed on the GPS tab isn't used for anything then?
I'll point the ntpd in the Kiwi BB to my ntpd with PPS and see what happens
course and coarse! Not a good thing to mix up in the GPS world... I meant coarse clock.
Great Info! I have a similar problem in that I live near 3 or more strong AMBC stations. I just put my Kiwi on the air yesterday and my initial solution was to add a 1800KHz HPF but I was going to start building something simllar to what you have n…
alliedelec.com/mean-well-usa-rs-25-5/70069562/?mkwid=siRZqQtpJ&pcrid=30980760979&gclid=Cj0KEQiA_KvEBRCtzNil4-KR-LIBEiQAmgekF3_z_oJ-xw97SJj9-SmhAHESTL5T9twAfWYrGzP6kDAaAosE8P8HAQ
Tried to add link but nogo
House them in a Faraday cage.... it's practical to build one using wood, sheetmetal, and bronze screen.
There are various HPF filters such as http://www.stridsberg.com/prod02.htm but you lose the LW and MW band. I was lucky to have one of those and diagnose things. I am now lookign at ways to notch the strongest signals in the MW band. I have one that…
Here's a source for Type 43 http://www.mouser.com/ProductDetail/Fair-Rite/5943003801/?qs=Ca1fAiqt1aqdvI%252b3p7fLXQ%3D%3D&gclid=Cj0KEQiAtK3DBRCBxt-Yxduq5p4BEiQAbFiaPVjDBD0ZimGD3OST73DDPxotP1lkGR_BFFmXfOD5_vwaAmo28P8HAQ More info: http://www.yccc…
