- WA2ZKD
- 16,165
- 14
I have found that a pretty nice single notch can be made using ready made off the shelf components. 30+ dB. If you are interested, contact me and I'll provide more info. KD2OM using one on 1310 KHz
No sign of an OS Level reboot, but additional kiwi server reboots. Leaving wspr off for now
over the months, I added a the notch filter described here: http://forum.kiwisdr.com/discussion/593/am-overload-solved#latest With that is place I have been able to explore the entire range that my antenna permits. I have almost 75 stations from 60…
martein.home.xs4all.nl/pa3ake/hmode/bpf_notch.html
doesn't Debian have a wait for network option at boot?
Phil.. I let the Kiwi/BB use DHCP as that is the default. Then in my router, I set it such the router "locks" the relationship of the Kiwi/BB's MAC address to IP#n. That way, the Kiwi/BBwill do a DHCP request and always get the same numbe…
I stopped when I got to short-term repeatably of < 3 uS. That's enough to discern between a groundwave signal and a skywave one when each end has that precision. I used that technique on my "day job" (Image)
One option if you can it to lock your router to use the same IP# to the kiwi MAC and then the kiwi can dhcp and get the same address
I am sure at some point John will add such tricks! I wish I was a better coder as opensource means anyone could do these kind of things.
yes those are Callsigns which means every DGPS TX has 3 forms of id.
top right corner
Yes, I have seen those. My question is what kind of ID is it. Ref. ID and TX ID are another value and is it an FCC callsign?
Nothing on this?
the DST is wrong here in Rochester NY also. should be UTC-4 and it is -5
it may, could you post a pix of it?
Seeing this now via mu command, note 2nd line Apr 18 17:57:01 kiwisdr kiwid: 8:46:41 012. 2 14096.35 kHz usb z14 "W2RFC" ::ffff:50.48.213.246 (LEAVING after 0:02:01)Apr 18 19:02:25 kiwisdr kiwid: 9:52:04 01.. 1 26s jig <> 22 #…
I have a Perseus too, keep in mind it has preselectors as it is single user. I use notch filters on the strong MW stations and keep most of that band usable.
Some TX stations have actual "bonus signals" (spurs) and that solution fixes those too.
That's it.
Thanks, makes parsing it by field a bit more work!
Martin and I have tried a few things. Even lighttpd minimal slows the kiwi portion. So as you suggested, run a second BB (or RPi etc.) But..... could you possibly add a page into the whole existing scheme called station.html where people could p…
The Cisco RV325 is a small business device so trades off user-friendly for feature-set and security
Martin, note that I started a topic on webpage
I'll write up a cookbook for JNJ
there is no lightpd running, so one would have to install it and let it run on Port 80? Again trying to help JNJ
my question my actually on behalf of G8JNJ.. a Linux newbie
after digging through the docs/setup.... enabled uPNP Cisco RV325 succeeded
If the memory and CPU of the BB could handle it, something like https://en.wikipedia.org/wiki/Lighttpd would work. Perhaps John will indicate if it might.
It's OK as is, I am now doing better notes!
Even though I saw no evidence of PS spurs, I have since switched to a Linear Supply. I also designed a 3 channel notch filter scheme to overcome overload on from nearby AM BC stations.
