- WA2ZKD
- 16,165
- 14
is the [SND] still needed?
I continue to be a fan of Acopian 5EB250 modules which are 5V 2.5 amp. They come up on eBay for about $40
I never get feedback about my system as to which category it falls into, even though the owner/admin link works. Surely the votes tell no story.
So when a station name pops up in the logging window/area that means it is TX but not necessarily heard (?)
from the admin webpage, use the console login and enter mu
mu command from ssh will get you info
I still long for local wspr control via a ssh login that could run in the background
that is part of what messed me up earlier in the week I think
Very nice.... As these improved lists etc become available, an accurate frequency coverage listing becomes more relevant. For example, I know my systems works to 10 KHz, with reduced performance below 100 khz but not to 0 khz. K2ZN has a HPF so only…
browser cache issue OK now got there by changing offset from 10 to 0, now back at 10 and a refresh
my system is back on line. John might be able to explain what I did wrong
1.122 did not fix
Obviously that should read v1.121. My system is off the air for now until that is solved
what bands/freqs do you notch? I have to do that in the 550-1700 range on a few stations but still have pretty good coverage even there. http://rx.jimlill.com:8073
I agree on the geo thing, also a sub-sort on freq coverage
FWIW, I evaluated a MFJ loop and it's pretty good. I have Pixel and Wellbrook for comparison
the voting has little relevance anymore
seems like an extension for tracking one chirp TX could be possible (?)
http://ulcar.uml.edu/framesn.htm#20
Related Data here:http://giro.uml.edu/ionogram-data.html
that is what I meant....
I have the Kiwi on my "IT Shelf" in the basement and I don't think I see this even though it is nestled up need my router etc. I have #31 ferrite on all the cables and also have it under a Faraday shield.
if Windows, this should do it I think. https://downloads.tomsguide.com/Virtual-Audio-Cable,0301-31100.html
what operating system do you run browser on?
what happens if you connect a PC directly to the Kiwi and shut off other network stuff? (as a test)
I open up 4 sessions within my local network. The data usage shown is from kiwi to that network. I assume, if they were external, that's the data that would flow
Android seems OK
https://www.html5rocks.com/en/tutorials/getusermedia/intro/
I have a good array of NDB below 550 KHz you can try that on http://www.jimlill.com:8073
this may help you https://learn.adafruit.com/setting-up-wifi-with-beaglebone-black/overview?gclid=CjwKEAjwqIfLBRCk6vH_rJq7yD0SJACG18frFfCy9GqQkWukdbxb4eYVvT0hZ2dDVGK8uSf2A7C_BRoCZc_w_wcB
