- WA2ZKD
- 16,165
- 14
12001.x, x=1-3
I can only speak to the samplerate bug. Currently, the resample option in any python application does not do any fractional correction by fixed point math. I found that while trying to compensate the kiwi's slightly higher than 12,000 rate. sox ca…
I use sox for fixing sample rate issues
available for linking.... http://www.jimlill.com:8088/indices/idx.png
thread title is "Random Power Cycling" but is sounds more like random reboots
have you run a df command at os level to check available filesystem space
Perhaps related.... I run Linux and Chrome. Over the years I find that if I sit on the GPS Az/El page in Admin overnight, things lockup my system, not the Kiwi. I reported this a long time ago and agreed to not do that anymore since it hurts!
put in /usr/local/bin
a script to do what?
get into the admin page, open the console and you can change PW
what is URL of the kiwi?
The limiting factor is the FPGA on the Kiwi Cape IFAIK. A Dragonfly SDR is a way to experience the limits of USB & Host CPU.
you can use the 8 channel mode it you can tolerate less WF channels
grep LEAVING upper case
can you access the console from the kiwi admin page?
run the kiwi's wspr extension on the 630M band and see if you receive anything overnight
KA1GXR@ARRL.NET
Honolulu on 12579 booming in here in western NY @ 1330Z
did you look at the HF schedule that is in the esxtension window? I think that the red/green is normal, just noise...
KA1GXR is the owner of that Kiwi Did you look at the NAVTEX extension in the kiwi's extension pull down?
that answewrs it, thanks
is there an option to not produce wf data for kiwirecoorder?
I have used the notch method on various HF sites I manage, not just Kiwi. Takes very few parts.
I find that after hours of FT8, it sometimes decides it's on a new freq 0.00, audio underruns and dies. Memory leak??
An interesting resource https://feodotracker.abuse.ch/blocklist/
got it, thanks
that's not so dumb... I see it can do VLAN so it can also do some interport routing...
what model is your Cisco switch?
what happens with local connections (on the LAN)
HF traders use some tokenized data scheme and a lot of FEC
