- WA2ZKD
- 16,165
- 14
I tried a W7/Chrome box today, no issue noted. I'll try what you suggest above as the evening here wears on.
My shadow to the north is caused by a large hill Edit: or so I thought, looking at a sat constellation map, there's none up there from me!
https://electronics.stackexchange.com/questions/11884/how-many-gps-channels-make-sense
antenna.com/artifacts/2016129GPSL1-TMG-SPI-40NCB.pdf
(Image)
this is a bullet proof PSU solution https://www.ebay.com/p/Acopian-AC-to-DC-Power-Module-5EB250-Ps1/1006182878
flashing LEDs is it announcing it's IP address which is normal starting with version v1.174. We're at v1.175 now. I think all is well for you
when did you put it on the air the first time? what version of code was running before the outage?
I have been trying various alternative GPS antennas, including a "big" one which I'll report on it a few days. However, if you look at the data sheet for the supplied patch unit, they specify a 70X70 mm groundplane for their gain spec. I c…
I think Ronnybrook has a nice ring too :-)
You might want to explore the Grove I/O
these Acopian remain my favorite https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2047675.m570.l1313.TR0.TRC0.H0.X5EB250.TRS0&_nkw=5EB250&_sacat=0
or http://www.oracle.com/technetwork/java/embedded/embedded-se/downloads/javase-embedded-downloads-2209751.html
I will explore this stuff on my spare kiwi https://packages.debian.org/search?keywords=openjdk-7-jre
Spec...http://qzss.go.jp/en/technical/download/pdf/ps-is-qzss/is-qzss-pnt-001.pdf
Related stuff here. I imagine the low end of that balun doesn't do well at LW but the board could be the base for alternate toroids http://www.nooelec.com/store/sdr/sdr-addons/balun-one-nine.html
a look at page 2 here shows the screw terminals are not balancedhttp://kiwisdr.com/docs/KiwiSDR/kiwi.schematic.pdf
On my Android Tab, it is full-screen and the positioning of the panels is better
CHU 3330 is loud most of the day here in Rochester NY, and the decode works well
I ordered some stuff, so will know more soon
http://denkovi.com/application-notes
how about a way for local user to create log on BBG and access via admin panel
the missing file is back...
John will surely answer but remote "watchers" load the system as much as normal users I believe
where are the controls for FSK?
doesn't java have LocalStorage?
I am doubting I got the area III stuff right. Having a way to hard log would help!
I have been logging a lot of Europe from here in WNYIn the last 2 days, NAVAREA III Stations: C,G,H,I,U,X
I am curious who else may have tried the DX mode, particularly on 518 KHz.
Thanks for DX mode, works great!!
