- WA2ZKD
- 16,165
- 14
by adding a BPF, you'd make it a single user receiver, unless everyone wanted to be on the same band! What problem are you trying to solve?
Congrats.... I have been hearing Steve lament for 30+ years not hearing it.
Martin, in Rob's wspr scheme the processing delays are no different than in wsjt-x as it uses wsprd. The use of a 2nd device, RPi or whatever assures that there is adequate computing power to assure timeliness of everything. The inability of a kiwi …
if you haven't bought the RPi yet, consider an Odroid XU4 for even more horsepower
Only 1 instance of FT8 is running at a time, correct?
DGPS can be done with an external decoder by piping the browswer audio via a VAC to something like Spectrum Lab
I think you'll run out of mips on the BB
0.2 ppm is pretty good for most everything (else). The Iono stuff needs a stable TX too.
I note that the high-quality shielded Cat cables have the drain wire tack soldered to the metal clip at the plug. Sadly, I have also found that "professional" installers often do not even deal with the drain wire on installations in busine…
Kiwi starup inrush is high but the run-time power is < 1 amp.
Glenn..... "There ain't no such thing as ground." But what about the all powerful Green Wire? I'm forever disappointed at how many people, even in the radio industry, don't get it!
You can do this with an external decoder on a 2nd computer. An elegant solution would be Rob's kiwiwspr.sh scheme. You might also consider the use of WSPR-15
just looked at my 4 kiwi and don't see the red S on any of them...
many of your "looks" are rather low angle, I wonder if that's part of it.
the wspr extension follows the preassigned bands, you can't force it to a "non standard" freq. AFAIK
Glenn, you'd have to run kiwirecorder on another computer like Rob does with kiwiwspr
you can use kiwirecorder.py to capture an audio file and then process it with a standalone decoder. No browser needed.
Congrats to Steve KD2OM on his logging of 8Q7HI Maldives on 30M. One of 3 wspr reporters in US to do so. Steve has been second only to K9AN for unique spots in the US for a few weeks. Credit should also go to John for the kiwiSDR and Rob whose ki…
I have a ballsy linear PSU on a UPS, never see any problems on either kiwi
swap kiwi cape with one on one of your others and see if problem follows it
Mike, Is your kiwi public? Is it the same on both the Pixel and the Wellbrook?
Picture of my system 12 channels of wspr using Rob's script (Image)
I note the OV (overload) is on, what signal is causing that? That and your noise may be related. Is the OV on continuously?
https://github.com/EliasOenal/multimon-ng.git
just ran across this https://github.com/EliasOenal/multimon-ng
You may also wish to use the beta wsprd which is now at 2.0 rc3 as it offers +1dB better SNR
I'd be happy with a NO GUI option. Just 8 (or more) channels that could only be accessed by kiwiclient etc.
most of the grove stuff that is easy to get going on a BB is written for debian stretch whereas kiwi is at jessie, so have to sort that out
a little humor..... I have both WHAM and WACK nearby but neither cause problems :-)
