- WA2ZKD
- 16,165
- 14
a wife friendly GPS window sill mount might be a picture frame with a ground plane on the back, looking like a A frame from the side, with puck facing out and up out window :-)
Drift OK, no roof access though.
Ron, look at the Degen/Kaito MS-31 type loop
I am thinking about something stuck on the glass...
I opened another kiwi here without 20 KHz to get my TDoA back online.. http://jimlill.com:8074
I live at 43 deg N 77 deg W and have to use "aiming caution"
The magnetic poles are not in play here, it's the geographic poles. (Image)
is it the mag poles, or those null coverage areas that scallop the extreme latitudes?
There's a lot of people running kiwiwspr, no wsprdaemon. Below is a snapshot of middle day results for today, rank reflecting most uniques. That's the top ten in North America and 5 of them are running kiwisdr + wsprdaemon. Special congrats to KD2O…
HNY..... I posted something on that awhile ago.... http://forum.kiwisdr.com/discussion/comment/4705#Comment_4705
I will be opening up channels on my wspr boxes at some point soon..
I set mine to zero available for TDoA
my Chrome shows now of the little sdr.hu icons... seldom look there until the 20 KHz edit: none on the endmemo page either.... font install to OS fixed it. But why firefox didn't need it?
I just realized that Linux/Chrome on my system does not display the 20 KHz etc. icons on sdr.hu, just a little square box. Firefox is OK though.
OK, if we are asking, how about a 2 ch 30 KHz mode for those chasing the new 24 KHz WB waveforms
John: thanks so much for the new mode/BW. I intend to use it for some multipath studies.
If you have multiple kiwi you need to put them all on 10 Mbps and then turn one at a time back to 100
broken wire SNR is the same as non-broken as long as not system noise limited
HF WB technology uses 24 KHz of spectrum... Harris and Rockwell both have sold systems that are in use
2G ALE is still is use but is being replaced by 3G, 3G+WB (Harris Proprietary), and 4G (not yet totally defined)
have you tried using I/Q and an external decoder?
have some fun.... try a command like this http://rx2.wa2zkd.net:8073/?f=1450/0,10000lsb You may find you have better fidelity. There appears to be a bug though, as that gave me usb but one sideband or the other is all you need.
Thankfully, I only have to filter 3 MF AMBC TX and do so with notches that are not otherwise very impactful. That's on WA2ZKD here in Rochester NY. WA2ZKD/1 in Rockport Maine lives without filters. Both stations use Pixel Loops although I'll be swi…
I put 20 dB of attentuation inline, more than enough, then went and looked at the strongest signals in the AMBC band, making note of the signal strength. A little math on those can tell a story.
http://www.rockypointhistoricalsociety.org/rca-radio-central/
WA2ZKD/1 in Maine with Kiwi and Pixel Loop did NOT hear it
I had good luck using Spectrum Lab for DGPS. Windows and will run in Linux using Wine.
Steve is in Victor NY, a rural area SE of Rochester
I would suggest you use Rob's 2nd computer scheme. It was kiwiwspr.sh but now wsprdaemon.sh. It will service all kiwi channels without any issues.
I need to get back to this project... has anybody tried any Grove stuff?
