- WA2ZKD
- 16,165
- 14
(Image)
(Image)
and fine notches they are..... deals with the killer MW BC TX that are quite close to me. 3X -20 dB notches that are pretty narrow.
by sync, I mean the XO freq and phase...
see http://kiwisdr.com/quickstart/index.html#id-user-tune
my latest config... visible in this pix are the filters, a DIY 3-notch for MWBC and a NooElec AM band reject. @ kiwiSDR are wspr and one is a 3 channel public unit (Image)
flat square is a GPS 4-way spliiter for 3 kiwiSDR and my nptd RaspPi https://www.gpssource.com/collections/commercial-gps-components/products/s14-1x4-standard-gps-splitter?variant=10809568899 used from eBay Blue box is a mini-circuits https://www.m…
I agree with John, external decoding rather than wspr-autorun is better suited
any Kiwi will have a delay in the RF to audio path, it's the nature of the design. It is not like other SDR in that regard.
When you try this, start by setting your scan width to 0-30 MHz to assure you see something initially
you might want to consider setting up AI6VN's kiwiwspr scheme for your 6 channels, you surely spot more stations with no other changes
Here's some codar I recorded using combined 20.25 KHz streams (Image)
In addition to the intended purpose of being a propagation reporter, some people are doing an informal "wspr challenge", who can spot the most. Since some reporters are using multiple receivers on the same band and report each as a spot,…
That should work fine on those "low volume" bands. The BBG can't handle high volume bands and that's why Rob developed his external method that can handle 1000+ an hour
The ability to superimpose a line on the waterfall that represents a known sounder sweep might be a start. If an actual sweep was received and visually aligned with the superimposed line, you'd know the sounder was being received. That might be eas…
AFAIK, he considers it still to be in beta test. KD2OM and I have been working with him on a number of refinements and bug fixes, some still open.
could you post a screen shot of your own IQ Display
this display? (Image)
Pi supplied PSU is a SWM, so can be noisy.
checked my TV's, none of them
There are no switchers on any of the RF related gear. The network switch may have one though. My next mission is to sniff with my "RF Explorer" spectrum analyzer. My trusty Sony 7600 has failed me!
latter
update can take 5 minutes +
one of these would do it.... https://www.mouser.com/productdetail/renesas-intersil/isl80103eval2z?qs=sGAEpiMZZMurtJ7VwBTl0QuDiV8KVz%252bnt8TSOSoElwE=
perhaps.... let's just say a linear regulator!
The USB pack I have seems pretty quiet.... but I suspect it varies widely...... A 6V SLA battery with a 5V LM7805 type regulator is a certain quiet way.
it's just a battery
run it off this while charging the battery off your linear supply. https://www.adafruit.com/product/1959 Get one or 2 of these to monitor things https://www.adafruit.com/product/1852
you can delay the load from being applied to the PSU with a simple relay.
Update: I successfully updated to Mint 19 and installed the other packages needed, and it built. Now to figure out how to use it!
