- WA2ZKD
- 16,165
- 14
did you try running catsync in wine?
look at the --help on kiwirecorder.py
http://forum.kiwisdr.com/discussion/1517/diy-downconverter#latest
It also runs on Odroid with Ubuntu
what devices are connected to the router and where are they located?
Use of the small shortwave portable radio is always a quick way to zero in
I have an old trusty Sony ICF7600G that I can walk around with and sniff out potential noise sources.
https://www.ebay.com/i/113664791414?chn=ps https://www.ebay.com/itm/ADF4001-RF-module-200MHZ-phase-detector-Frequency-synthesizer/272564042804?hash=item3f76153c34:g:fbsAAOSw32lYrA47
Click on the square green icon with arrow near the frequency is
https://www.ebay.com/itm/New-SMA-connector-band-pass-bandpass-filter-BPF-118-136MHz-for-Air-band/123134437372?hash=item1cab6267fc:g:XHAAAOSwxQha-rQG&redirect=mobile
where on your property to you have the puck located
If you can go through the tedium of installing gnuradio and gr-kiwisdr there's a tool that allows you to measure the magnitude of signals and their SNR. It is helpful. As is walking around your house with something like a Sony ICF7600 of equiv.
'crow.... I think you mean downconverter.
you might mention a freq./signal you tried
Chris... things like kiwirecorder.py and gr-kiwisdr can do some of this stuff
that was implemented when there was snow on the ground.... more to follow!
it can be hard to quantify but my wspr ranking (number of uniqs) went up several spots since implementating that 2nd ferrite scheme
I used a +40 dB unit to overcome feedline loss and eliminate need for active splitter. Instock wireless (link above) has bias tees.
that's a little tricky because you have to consider the sum of all the big signals in the HF range, not just what you see. I use S9+40 dBm as my goal when filtering, notching or nulling the biggies.
Time-Pi is a Pi with an Adafruit GPS board that has been setup to provide a local ntpd with PPS Stratum 1 accuracy. Even if I lose the external network, all time is very accurate.
If you want LW and MW, be conscious of the low end cutoff on any scheme you use
IIRC, the wspr time comes from the kiwi's internet time.... and of course has a fair amount decode freq tolerance, given its wide decode window
These guys have reasonably priced passive splitters https://www.instockwireless.com/gps-splitter-4way-type-N-gps400.htm#
The "black blobs" are 31 Mix Ferrite cores. Something like these https://www.digikey.com.au/product-detail/en/fair-rite-products-corp/0431173951/1934-1429-ND/8593999 75 Mix is good but harder to find and more $
I use one of these.... https://www.minicircuits.com/WebStore/dashboard.html?model=ZSC-3-2+
receive WWV on 2 time stamped IQ files and look at alignment (?). I know you have WWV on GW so no skywave effects!
The spliiter is a passive one, the DC applied gos to bias the GPS unit, which is this case is a +40 dB gain unit. https://www.ebay.com/p/PCTEL-GPSL1TMGSPI40NCB-Antenna-Kit-GPS-L1-Surge-Medium-Duty-Mount/2006284562?iid=123183788371&chn=ps more i…
jimlill.com has 8073, 8074, 8075 ports
I am less concerned about absolute accuracy than the relative accuracy between 3 kiwi
The lack of phoro height was the issue, thanks
