- WA2ZKD
- 16,165
- 14
if you want to catch all the 80M spots, you need to do both old and new sub-bands, they are both still active
it was a joke! buy as... bias
what does that buy us!
I was involved in the design of a similar antenna 25 years ago..... I'll see what details I can find.
I also played with json->csv conversion to import into Excel, but concluded the hand edit of json worked adequately http://www.convertcsv.com/json-to-csv.htm
I edit them my making a copy of dx.json and editing the copy. copy the new file back to dx.json and restart the server. the json format is easy to grasp for edits.
FWIW, related info: Product Name: TP-LINK TL-WN725N V2 Chipset: RTL8188EUS https://www.raspberrypi.org/forums/viewtopic.php?f=26&t=29752&p=342506
filtered D are cheap if just ferrite but get pricey when there's a network
I wonder if a layer of this between the BBG and Cape would offer any advantage https://www.dupont.com/products/pyralux-tk.html
Christoph is on holday IIRC. He could answer...
I intend to make some new ends via CAD/CAM soon
Nice report..... are the PSU linear?
looking at VA7WWV as a user, all seems normal. You even have the all too typical spurious at the high end which can be usually reduced.
I run Linux and the equiv. VAC there but I think you need a W10 VAC users to give you specifics. Confirm which VAC you are using
You don't configure the browser. It always feeds out the same place. That is handled in the VAC
There's no setting in the browser or the kiwiSDR*. It's all the VAC and App you need to configure. Please mention your OS and Apps so others can help. * mode is likely I/Q but again it depends on app
https://hackaday.com/2019/07/19/inside-the-mysterious-global-navigation-outage-you-probably-didnt-notice/
any study of the ionosphere would likely ignore "flyers", high or low, and those could simply be ignored in the logged data. I have suffered through a lot of OV stuff here and am not sure that factoring it into such a study would work. Fo…
An issue I foresee is that a single "fire" of the OV may not align with any gain compression or other phenomena. I have observed that here and John has mentioned it over the years (wow, it's been years now)
GPS performance can be affected by signal strength and multi-path. The latter can be quite an issue on indoor and/or window sill installs. On my day job, we did a study of GPS and ending up getting rid of a commercial module in one of our products …
Martin, are your loss values measured thus including the 50-75 mismatch loss?
I only await a PayPal e-mail to send my $
with the 40dB gain antenna and short coax, you may be putting too much signal in... so the long coax is a good thing
Is your puck on any ground plane and which side of the building is it on?
That map freezing occurs on my Linux Chrome browser too..... has for a long time.... not thought to be a kiwi issue
Mini-Circuit makes some stuff that would work and you can often buy them surplus on eBay quite cheaply. For an amp, I use a ZFL-500 and for splitter ZSC-3-2+
What kind of antenna are you trying to split?
https://www.mouser.com/ProductDetail/Adafruit/1030?qs=GURawfaeGuDayVAvxlYL4Q%3D%3D&gclid=CjwKCAjwvJvpBRAtEiwAjLuRPdvUJMiGKfnKQcYRmNm1_0kxmSGP6f3eee6TUVLCxcu2RBgT2RWRcxoCDywQAvD_BwE
http://forum.kiwisdr.com/discussion/comment/3677#Comment_3677 look at jimlill.com:8073, it has 3 notches in the MWBC band as I have local TX just about 1.5 miles away. rest of band is usable
Nice work.............. very similar to what I was going to do, but project got pushed aside for now
