- WA2ZKD
- 16,165
- 14
Ron, have you looked at these https://www.adafruit.com/product/706
Just ordered 2 units so will have something running next week
I have 3 kiwi, all currently on the same antenna. 2 are used 7 ch. each for wspr and one is a 3X20KHz public unit, for 5 public channels. I also use #3 on alternate antenna schemes for experimentation at times.
I think it's an ISP thing. If I connect in work, I show Florida because our corporate grid ties in there.
Interesting story here https://rntfnd.org/2019/07/15/galileo-signals-not-to-be-used-then-we-were-never-operational-anyway-europes-gsa/
added station
I have a Soundcraft Ui24R mixer (for live music) that uses html5 very intensively and it was crippled by the current W10/Chrome upgrade combo. The latency made it impossible to use. There were also some buttons that went unresponsive entirely. Live…
There are known issues with latest W10/Chrome and html5. Try turningh HW accel off in Chrome adv settings
I agree with Martin... or, maybe a PW scheme for such data
has anyone got this going in Linux yet.... stumbling a bit here
yeah, neither 75 or 90M BC band
It is..... online streaming stuff, wonder how they find the links
found issue, I had changed the port for sshd
Thanks, will try again....
http://www.rfcafe.com/references/electrical/noise-figure.htm
What type of antenna will you use?
I thought your previous post suggested it might be a thing to do (?)
beyond my coding skill... but here's where to get almanacs https://www.navcen.uscg.gov/?pageName=gpsAlmanacs
He'll have to explain it. I can access his remote unit NP, He can access mine NP. But yet, depending on how he routes (his report), he has the white noise issue.
Keep in mind that a look to the North, or if you are in the South Hemisphere, to the south, can be fruitless for sat views
It's a local problem.... routing issue.... I have helped him
I use TTFF on the admin GPS page as a quick metric on how GS in working. A range of 42-48 is what I typically see. Its use is mentioned in the doc I linked above.
see section 5.1 https://www.u-blox.com/sites/default/files/products/documents/GPS-Antenna_AppNote_%28GPS-X-08014%29.pdf?utm_source=en%2Fimages%2Fdownloads%2FProduct_Docs%2FGPS_Antennas_ApplicationNote%28GPS-X-08014%29.pdf
Some of this discussion is a result of the confusion as to what is a given frequency. Even in the professional community we suffer due to misinterpretation as to the terms used to describe the use of a frequency. The one that I seldom see in the ho…
I have 100's of NDB logged (although here in US they are taking them off the air one by one) and use the scheme shown below. the 400 Hz offset is for Canadian station, US would be 1000 Hz (Image)
You don't need anything elaborate but here's some guidance http://forum.kiwisdr.com/discussion/comment/3677#Comment_3677
a simple L-C notch should do that...
Thanks
local login with pwd does not open up blacked out spectrum either
on my chart I think of them as 80 and 80eu
