- WA2ZKD
- 16,165
- 14
Has anyone logged VOK on 3560
I have successfully made my BBAI based kiwiSDR accessible by both eth0 and the AI's internal wlan0. I'll post more details after more testing.
Incremental report.... Following this precedure gives you a wifi client, to your central router, persistant across power cycles (Image)
I think I have a handle on this but need to do more testing. This will elininate Cat5 conducted spurs etc
From observation of many other kiwi, I am seeing that many don't get DX Label work so sysops aren't familiar I guess
There's this info, as applies to the BBAI itself... I'll explore a standalone BBAI with this first https://github.com/beagleboard/beaglebone-ai/wiki/Quick-Start-Guide
I have some noise coming from my next door neighbor. The source seems to be on a timer, so I assume lights.
as an admin, use the same method you use to label for a frequency, there is a blacklist option in the pulldown
you might consider blacklisting that freq.
what freq did sit on?
what is the basis of your blacklisting all those?
thanks to both of you for the effort...
Yes, I have noticed the sked updates.... thanks
link for Romania webpage https://www.rri.ro/en_gb/frecvente-259
1/16 0950Z WINB 7315 in WNY
Christoph provided this link for DRM info http://stuckis.com/DRM/
funklust seems unlikely.... there's a kiwisdr right at the campus there and it hears nil
Today 14 Jan @ 1925Z (times align with kiwDRM schedule): 5995 Romania 7235 Romania 7550 India Enough SNR to get decode to confirm DRM at 2100Z 6030 Romania 7550 India at 2200Z 9490 Romania 2300Z 6040 Romania
I'll start adding actual loggings, freq and time here. Maybe others can too and then that info applied to the schedule.
I believe that directKiwi connects had no time limit, so 1.371 should fix that
Budget should not be a problem for the whri people
I found this but nothing more recent https://www.drm.org/wp-content/uploads/2018/12/DRM-Transmission-in-SW-_B18_1_28112018.pdf
I was just checking on Inida on 7550 with DRM but the time slot doesn't match the kiwi schedule
(Image)
KD2OM capture on his Flex 6600 was at a lower level than on my Kiwi
I am only guessing, but I bet it's a browswer cache thing. I have 2 units running v1.369 and don't see that
what is 1.369?
as nice as Mikrotik are once working, configuration can become an adventure
Possible bug in 14ch AI... 13 channels in use, tried DRM on 14th, seeming crash
I'll have to check with my shipboard antenna cronie and find out
