- WA2ZKD
- 16,165
- 14
Ron, Nada here at 16:46 wrong MUF for my qth
2 of my BBAI upgraded w/o a issue... one per schedule, one I forced
if you're running WD.. let me know so I can include you on my ranking analysis. See ranking page and my e-mail contact at http://www.wa2zkd.net:8088
Hope you get better John....
kiwisdr and upgrade are usually PnP but that first one got problematic along the way
I have some loops I made using fiberglass fishing net hoops inside of tubular braid. Flexible yet hold their shape rather well.
replace the unwieldy brown wire with a simple piece of #14 bus wire
I don't like touching a soldering iron to my kiwi or BB so got some DC blocks from eBay. But, I'll DIY my next ones. A 15 or 18 pF series cap would work. I don't think the kiwi cares about antenna sensing, so that simple cap should suffice.
sytem running very well for 5+ days and my wspr spots have improved... seems like less RFI
I am a fan of used Acopian Linear supplies. Industrial quality at a reasonable price. May you have access to them or similar in the UK https://www.ebay.com/sch/i.html?_fsrp=1&_sacat=0&_nkw=acopian+5v&_from=R40&rt=nc&LH_TitleDes…
it's "normal"
Yuri, Given the 33-34 deg temps I am seeing, I doubt that I will see an issue.
BBAI has connman already installed. Has anyone tried adding connman to the BBG?
all systems running now... 2 unloaded kiwi/BBAI run 31 deg. and the 2 with 14 channels of continuous kiwiclient run 34 deg, in my cool basement
http://www.jimlill.com:8073 and 8075 are the public access boxes and now both back online. 8073 is on a Mag Loop and does 3 X 20 KHz channel mode 8075 is on a vertical dipole and does 2+6 X 12 KHz channel mode
thanks for the heads up.....
Project is done mechanically, just needed to update the firmware in everything, configure and hook up antennas. Pix may be viewed at https://www.dropbox.com/sh/x7tt18loi84bpg3/AADLeN3iU6g7ZoPi520opbQpa?dl=0
I assume they are all "behind" the same router, kiwi and Pi. How do you handle your 192.168.x.x. (or 10.10.x.x) IP # assignment? DHCP. Static or ? I lock the device MAC to IP# in the router and let the device run DHCP. I wonder if your L…
got it running here... will have to use it some..
Besides offering up to 56 simultaneous connections/channels this allows use of up to four antennas or filtered antenna paths. I have had 4 kiwis running for months, but never mechanically integrated like this. I use 2 of them for wspr, a different …
this is now obsolete (Image)
Almost ready... removed paper ducts and with 4X 14 ch installed max temp at 100% CPU is 44 deg C, a 19C rise
The evolving kiwi cluster (Image)
It is adequate the way it is, so don't want to complicate it. The simple addition of that paper deflector was worth 1 deg !
Yes, I know what heatpipes are and perhaps I misstated that. By in effect, I meant it draws heat from the hotspot...
I'm not sure that my bends in those pieces make any real difference. They could be fab'd from 1/4X1/4 aluminum (or copper) stock. They are in effect a heat pipe.
Pi-hole might do it https://pi-hole.net/
simple alum. and yes I designed it and made them with a water-cutter. I'll publish the drawing. I have that cardboard baffle there to defleact the air to a more favorable path.
I have a Kiwi cluster of four units mounted on a single end plate. On that is a plenum/fan-mount with a single 80 mm fan. Testing, so far, shows the CPU temp never exceeds 46 deg even with heavy loading. (Image)
* combined with a virtual audio cable something like https://www.qsl.net/dl4yhf/spectra1.html provides a lot of tool. * https://www.audacityteam.org/ is another good tool * and of course there's something better that I can't think of!! :-)
